20 Most Recent
Lexmark MS410DN Laser Printer - Monochrome - 1200 x 1200 dpi Print - Questions & Answers
Service error 140.10 transport motor
This is a generic error message that can be recorded for a wide variety of problems. Basically, any time the Report Server has problems initiating an application it will record this message along with:
- Application name (i.e. WindowsService_21, WindowsService_13, WindowsService_8)
- Error description (and that can vary widely). Examples: "The endpoint cannot be created.", "The report server has encountered a configuration errorr", etc.
For more help visit
cbrtechsolutions
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
