20 Most Recent Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Questions & Answers
My electrolux Icon side by side counter depth
SO I have/had this problem. The knocking started almost 3 months ago when I got it. IT got to the point where the ice make will not work.
Just had the repairman out. He started out clueless but over the course of an hour he had the factory on the line, and got it resolved, I was watching over his shoulder.
The ice mold is on a cam. It drops down and around to the right to fill with water, and then back up into the center to freeze the water. HE got a kick out of how it worked, it is kind of cute.
When its going to the right to fill, there is a plate in the back right hand side that covers the copper freon line, it protrudes into the path of the ice mold. As ice/frost build up it bends it more to the point it will prevent the mold from swinging into the position to get water. Thats what happened to me.
There is a kit to fix. He did a temp fix:
1) With the Ice tray out.
2)Remove 2 screws on the front lower part of the ice maker and slide cover off.
3)On the right side 2 freon lines come into the ice maker there is a piece of plastic, maybe 2-3 inches square, with a slight offset to it. That's the problem piece. Remove it, and bend it a touch so it pulls it out of the path of the mold.
4) Reassemble.
WHen my kit comes, I'll just re-install it myself.
9/16/2022 3:33:10 AM • Electrolux Icon... • Answered on Sep 16, 2022
I have two problems with
There is no power up there - best you get a schematic for the unit so you can figure it out. The site enclosed often has schematics for this type of appliance. All you need is an ac voltmeter and you are ready to start checking. Search Over 2 1 Million Appliance Parts
9/6/2017 1:09:17 AM • Electrolux Icon... • Answered on Sep 06, 2017
How to replace broken water dispenser paddle?
Good Afternoon Friend, I understand you want to know how to replace the water dispenser paddle in your Electrolux refrigerator, model# E23CS786SS1. Typically, this is not a di it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to replace the dispenser paddle with ease. Hope this is helpful. -Best Regards- WP
6/27/2014 6:09:05 PM • Electrolux Icon... • Answered on Jun 27, 2014
Repair water dispensor Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator
Good Afternoon Friend, I understand you want to repair the water dispenser on your Electrolux Icon refrigerator. Typically, this is not a do it yourself job, as well as there are no instruction manuals that give step-by-step instructions. I suggest contacting your local authorized technician for further assistance. They are trained on your particular model, and will be able to diagnose as well as determine if there are any other parts that might be needed for repair. Hope this is helpful. -Best Regards- WP
5/29/2014 5:20:48 PM • Electrolux Icon... • Answered on May 29, 2014
Problem w self-closing freezer door
Good Morning Jan, thank you for your post! Sounds like the hinges could possibly be worn out due to the weight of the doors and how they are open and closed. In this regard, I would highly recommend reaching out directly to the manufacturer to see if they have any updated or alternate door hinges that you can install yourself. Best regards!
12/11/2013 3:16:01 PM • Electrolux Icon... • Answered on Dec 11, 2013
Ice maker not making ice
Hello KC Breen - If your ice maker has stopped producing ice completely, please check these, in this order:
1. Your ice maker may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency.
4. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
5. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Should these suggestions prove ineffective, I would recommend contacting an authorized service technician that will be able to assist you in the diagnosis and repair of your ice maker. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area.
3/19/2013 3:33:37 PM • Electrolux Icon... • Answered on Mar 19, 2013
Sencor start buzzing freezer working light in fridge off
Hello Frank Van Acker - Typically when the refrigerator is beeping or buzzing it indicates a warning of a possible malfunction or that it has detected an unsafe temperature inside. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective contact a professional to move forward accurately. The refrigerator could possibly be experiencing a communication problem with the temperature control/board or wiring failure.
1/10/2013 2:33:29 PM • Electrolux Icon... • Answered on Jan 10, 2013
Electrolux refrigerator not cooling
Is the freezer cooling?
8/7/2012 6:51:39 PM • Electrolux Icon... • Answered on Aug 07, 2012
My compressor runs for 5
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/24/2011 10:03:31 PM • Electrolux Icon... • Answered on Sep 24, 2011
The Electrolux refrigerator is not
First thing to check is if (a) the evaporator fan is running in the freezer and (b) if there is a build up of ice on the freezer wall. If the fan is not running in the freezer the ref. side won't cool. If there is a build up of ice on the freezer wall, then you a defrost system problem and there won't be any circulation to the ref. side. If you have a defrost problem, the defrost system consist of 3 parts: timer, bi-metal thermostat, and heaters. With fridgidaire more than likely the adaptive defrost board(timer) located in the fridge on the upper left side behide some white pastic is bad. If you change it go ahead and change the bi-metal thermostat, located behind the freezer wall, as well because its a very cheap part and will save you from having to do it later. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
11/1/2010 1:27:09 PM • Electrolux Icon... • Answered on Nov 01, 2010
My refrigerator is beeping and has high
your coils down at the bottom may be dirty & full of dust vacum it out. if the there is ice forming in the freezer it needs to be defrosted.
10/28/2010 2:44:13 AM • Electrolux Icon... • Answered on Oct 28, 2010
Deeep said cooling is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
10/22/2010 1:28:31 AM • Electrolux Icon... • Answered on Oct 22, 2010
The refidarator freezez everything especially on
it is prob a main pc board . it gets it info from the sensors and then control the compressor run time and the defrost cycle .. the fan when it failed may have caused over run times . . did you use the correct speed fan for replacemant . and are the coils clean. board may be good but sensor bad . .. i can hepl more with complete model # .. but try cking thes first .. mm
10/7/2010 5:08:56 AM • Electrolux Icon... • Answered on Oct 07, 2010
Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Logo
Popular Tags
78 questions posted
Top Electrolux Refrigerators Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Refrigerators
Most Popular Question
sencor start buzzing freezer working
  • Refrigerators
