20 Most Recent
Advantech IPC-6806SB-15ZBE: Industrial Desktop/Wallmount Chassis 6-slot Questions & Answers
How to correct problem during boot up
You should be able to go back-in and reverse your changes.
alternatively there are two other options.
1. Most BIOS have an option to 'load system defaults' or similar, which should get you back up and running, though you might have to change other settings to get it back to where you began your changes.
2. There is a a Jumper on the Motherboard that you can move slightly which will perform the same function. Some models require that the CMOS battery be removed for this task, most built in the past 5 yrs or so do not.
Without knowing what Motherboard you put in this 'shell', there would be no way to point you to the manual or the Jumper's location.
11/14/2014 10:53:54 AM •
Advantech...
Answered
on Nov 14, 2014
How i correct problem in boot up
The bios settings control where you boot from. That is hard disc , DVD , USB stick, reset the bios settings to original, then go to settings and follow instructions to set boot options , most computers have different settings
11/12/2014 11:02:23 PM •
Advantech...
Answered
on Nov 12, 2014
Ppc 153t
if it is damaged, then it will need to be replaced. You will have to determine whether or not it is an IDE or a SATA cable; although if you REALLY have it connected to a CD-ROM, then it is an IDE cable.
If you have local PC repair shops in your city, give them a call. They will have perfectly good 'used' ones they likely will be glad to give away....I know I do ! lol
If you do not, then you can get them online cheap here :
StarTech Model IDE66 18 Ultra ATA 66 100 133 80 wire IDE Cable StarTech...
11/13/2014 8:33:52 AM •
Advantech...
Answered
on Nov 13, 2014
Ribbon to hard are bad
Hi
Do you need the 40 wire connector ribbon cables or do you need SATA ribbon cables to connect the hard drive to the motherboard?
3/21/2009 9:21:38 PM •
Advantech...
Answered
on Mar 21, 2009
Mother board driver
You can try Nodevice.com
or type free download motherboard drivers in google search
9/28/2008 4:39:05 PM •
Advantech...
Answered
on Sep 28, 2008
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
