20 Most Recent
Gateway SX2110G-UW318 Small Form Factor Desktop PC with AMD E1-1200 Questions & Answers
My PC starts-up said my name welcome and stays on that scree with the spin next to welcome and that's it.
Sometimes updates running in the background act that way. You can wait it out (could be 1/2 hour or more depending on how many updates) or you can try holding "ctrl", "alt" and tap "del" key and see if "task manager" opens up. If it does, it should show what processes and applications are running. That may give you a clue. Finally, you could just hold the power button down a few seconds until it shuts down. Upon restart, you may have to select an option such as "start normally". If you continue to have problems after the restart you may need to go into "system restore" mode (type "system restore" (w/out quotes) in search box of Start menu, follow the prompts and choose the restore point just before the last system change. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/brad_a1804065c704c462
10/18/2016 8:26:29 PM •
Gateway...
Answered
on Oct 18, 2016
Gateway sx series sx2110g-uw318 boot menu
This is an snippet from the Gateway Website.
"In order to access the boot options on this portable computer, press the ESC or F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives or to enter the BIOS Setup Utility. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer."
1/27/2014 7:41:26 PM •
Gateway...
Answered
on Jan 27, 2014
Gateway sx series sx2110g-uw318 boot menu with AMD E1-1200
It's either F1 or F2. However, once I had a Gateway which needed "Delete". You can try to put one finger on each button and press them successively. If everything goes right, you will enter BIOS and then you will have to enable lagacy usb support, change boot order so that you can boot from USB or CD (it depends...). Hope this helps!
1/26/2014 7:03:58 PM •
Gateway...
Answered
on Jan 26, 2014
How to optimize Gateway SX2110G
Hello,There are a lot of ways on how you can optimize a computer. You can upgrade the hardware part of your computer which can boost up its performance or you can maintain the current the optimum capability of your computer by making sure that you have an anti-virus running on it and you have all drivers updated. I suggest you install RadarSync to automate driver updates. It's very important if you want it to run in its optimum level of performance. David
2/19/2013 11:28:04 AM •
Gateway...
Answered
on Feb 19, 2013
