20 Most Recent
Emerson MW8987B/W Microwave Oven Questions & Answers
Emerson microwave mw8780ss, door won't open
I can tell you what we did when we had that issue with our Maytag microwave. The door wouldn’t latch correctly and an appliance repairman said we would have to get a new microwave. My husband took the spring out and decided to just put the spring back. It had come unhooked somehow. He put it back and it’s worked fine going on 3 years later.
2/23/2019 8:21:19 PM •
Emerson...
Answered
on Feb 23, 2019
The door sticks on my microwave oven
Usually this is due to loosened mounts inside the oven.
The mounts hold the door switches and grab the door hooks when it the door is closed.
The solution is to realign and tighten the mount screws inside.
It's less liekly, but it could be a weak or worn door open lever inside.
I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
1/6/2014 3:41:18 AM •
Emerson...
Answered
on Jan 06, 2014
It does not heat up
Generally, the most
common causes of a failure to heat are:
- bad door switches or
door switch mounts
- loose or corroded
connection at the magnetron
- problem or loose
connection on the control unit circuit board
- bad magnetron
- shorted high voltage
diodeSee the following help files on safety & disassembly and door switches.You can find links to helpful exploded view diagrams and part ordering help
here.
I recommend that you bookmark that link to your favorites.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of
our answer.
12/1/2012 6:10:01 AM •
Emerson...
Answered
on Dec 01, 2012
Door not closing
If the door is not closing, the door latch is broken at the tip, or inner mechanism, or the door is out ot of position and not lining up.
3/6/2012 3:39:43 PM •
Emerson...
Answered
on Mar 06, 2012
