20 Most Recent Franke Flair Espresso Machine with MilkMate Questions & Answers
Where can I buy new seals or a whole new drop tray please
Franke Flair... | Answered on Oct 17, 2018
Google it perhaps U will get luck
Franke Flair... | Answered on Aug 29, 2016
The filter should be replaced at the intervals recommended by Franke.
Franke Flair... | Answered on Aug 15, 2016
If you are refering to the main cover! firstly the hoppers have to be removed. then the metal plate on the top(cup warmer) secured with 4 x t15 torx screws. once the plate is removed the main cover is secured with 4 oval headed screws 2 of them located under the plate just removed. the other 2 are located under the adjustment rings for the grinders. the main cover then can be removed. there are 2 electrical connection plugs that have to be disconnected .
Franke Flair... | Answered on Apr 27, 2015
If you remove the coffee outlet, you will see a little tab sticking out of it which inserts into the machine just above all the outlet pipes. this "tab" locates onto a micro switch. After a period of time the outlet can become misshaped(not noticeably ). if you squeeze the outlet gently it will temporarily fix it. the outlet will need to be replaced eventually and or the outlet holder.
Franke Flair... | Answered on Apr 03, 2015
its a brewer fault or brew motor.
Franke Flair... | Answered on Mar 06, 2015
there is no reset switch, please wait on the display indicates the machine is heating . but the sensors are not registering the temp. this means either the thermoblock/s have failed (unlikely) there are upto 4 thermal fuses mounted on the thermoblocks . this is more likely the problem. any more info required please et me know
Franke Flair... | Answered on Jan 13, 2015
the two main reasons for this are the on off switch located on the back of the machine is switched off. the other is the flap to the grinders is not correctly fitted. other than this an exporative visit by an engineer may be required. there are two mains fuses situated by the cable inlet behind the rear panel.
Franke Flair... | Answered on Apr 30, 2014
Possibly with a small stainless wire .
Franke Coffee... | Answered on Aug 25, 2019
Check the water level sensor on tank,often gets a bit of lime scale on it.Remove it give it a clean and replace and check
Franke Coffee... | Answered on Jun 30, 2019
Franke Flair Espresso Machine with MilkMate Logo
18 questions posted
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
jonathan Hanson
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Franke Coffee Makers & Espresso...
  • Franke Coffee Makers & Espresso...
Most Popular Question
often change water filter
  • Coffee Makers & Espresso Machines
