20 Most Recent
Dell Inspiron 13 Notebook Questions & Answers
Dell Inspiron 1318 webcam not working
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver
W7
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
right click to reinstall drivers or update driver hope this helps
Using webcam on dell Laptop
Why won't it start? Do you know where the application program is that starts it?Look in the program list for the application program that drives the webcam. Click Start/Programs and look for any reference to a webcam or camera. Also look inside the manufacturer folders in the program list, the camera might be inside one of them. Some manufactures put the camera in a folder or program that is called something like Entertainment Experience. Once you open it all the entertainment devices such as media player, webcam, etc. will appear as icons. Click the webcam or camera icon.You can always download Manycam and install it. Go towww.google.com and in the search box type: "download.cnet.com"(without the quotes). Click on the link to go to the site. When thesite opens look down on the left and you will see a gray area that says FindSoftware. Type "Manycam" (without the quotes) in the whitesearch area then hit the search mirror. When it brings back your resultslook for the one that says ManyCam Virtual Webcam. Down load it andinstall it. Make sure you remove the check box on any junky programs itwould like to install. You only want to install ManyCam, no additionswhatsoever during the install. ManyCam is totally FREE and easy to use,and you will always know where your webcam software is.
Hi
i clicked on a facebook
if you reinstall your laptop your d: will not lost, only the c: that will formated,or use another pc to see your hard disk
Driver dell pp25l
go to dell.com click on trouble shoot and then click on drivers and then you will enter your computer model and thats it
My dell laptop is plugged in but not charging
Try this: take the charger to a shop and ask them to check it. If it checks bad replace it. If it checks good then the problem is probably the connector where the charger plugs in. This is difficult to replace and will need a trip to the shop.
I got an open box laptop Dell Inspiron and the
With certain webcams there are actually 2 parts of the application to look for, one of them is going to be the console which is what you have found the other one will have various names but is often called the "Centre" which is what will actually run the cam for you. If this was uninstalled before you purchased it, you should be able to re-download the entire application from Dell's website. I would recommend uninstalling the console before you download the new software package.
Best of luck to you!
Running XP having driver problems
Try taking it back in time, and starting over.
Start > Help and Support > Undo changes made to my computer > Restore my computer to an earlier time.
Make sure that you select a date on the calender that is before you installed the new usb device, then follow instructions.
There is probably an address conflict that is causing the problems.
Good luck
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
