20 Most Recent
SNK RAC SAT NAV 200 GPS Receiver Questions & Answers
Sat nav won't reset. have tried the re-set button.
If the reset button of your device is not resetting the device and it is still on the frozen screen. Just turn to the back of the device, unlock the battery from the device and remove it. Then you allow the device rest for about 5 minutes then you fix it back in. Plug the device for about 2 hours and power it on. It should work fine after this. Be sure not to turn on too many applications on the device at the same time time, because that could result in the device being frozen again.
You can as well update the software of the device by charging it for about 2 hours, then you connect it to the computer that has its software. That will show if there are recent updates for the device, then you update the software with the latest version. that should take a little while to update. Then install your maps on it, safely disconnect the device from the computer and turn it on. That can also help you solve the problem.
Hope this was helpful. Thank you for using fixya.
When I put my RAC 500 sat/nav into sleep mode,how
You should be able to just press the screen and it'll come back to life. Failing that, press the on/off switch - if it switches on, go to Navigate, if it switches off, switch it back on again and go to Navigate.
