20 Most Recent
HP Mini 1010NR Notebook Questions & Answers
Cannot change desktop background
On your desktop screen; right click, Personalize.
What did you see in this screen? It should display Desktop Background (and it is clickable to change it)
How to do a factory
Hi, this how you can system restore your laptop. To restore the original operating system and programs using the System Restore utility that is installed
on the device, follow these steps:
1. Turn on or restart the device, and then press the esc key repeatedly while the "F10 = BIOS Setup
Options" message is displayed in the lower-left corner of the screen.
The "System Restore" page opens.
2. Use the arrow keys to select System Restore, and then press enter.
3. Follow the on-screen instructions to restore the system.
Please get back to us if this information helps you solve your problem.
My hp mini 8g is
If you have an HP mini like the 1010nr, you may have only an 8GB solid-state "drive" the solution is to: 1) plug in a usb drive to a side port for extra space; or, 2) BETTER - pull off the cover on the right side to access the hidden USB port and install a permanent large-capacity usb memory module, then replace the cover. This requires a small usb stick with little or no case (like this: http://www.ebay.com/itm/PNY-Attache-Paris-16GB-16G-USB-Flash-Drive-Stick-Purple-/250804063654?pt=US_USB_Flash_Drives&hash=item3a65164da6) -REMOVE THE OUTER CASE FIRST.
Notebook pc states reboot from network
Hi, usually reboot from network error occurs when the computer cannot detect the hdd on the computer where the Ooperating system is installed. Try removing the ethernet cable when you restart the computer. And also remove any devices that is connected on the computer via USB. If problem still occurs. try to send the computer to a local technician to check the hdd on the computer for errors. Thank you for using Fixya, you recommendatino is highly appreciated for the free support.
Fuzzy screen hp mini laptop
Try updating your graphics driver through Device Manager.1. Right Click on "My Computer" on your desktop2. Select "Properties"3. Go to the "Hardware" Tab4. Then select the "Device Manager" Button5. Click on the tiny + next to display adapters6. Right click on your display adapter and choose "update driver"7. Follow the instructions and let it search for a better driverIf this doesn't work then you will need to bring it in to a computer shop to have the screen replaced. Get an estimate first before they do any work on it because it might not be cost effective to have it fixed. In which case you can hook it up to a monitor with a VGA cable to still use it, but it won't be portable anymore.Good Luck!
No the password.but wont let us into the bios,it
Hi kellydmurry,
If you have the right password then you should be able to get into the bios , it could happen that the password you are entering is a wrong one , therefore without displaying any warning to you the laptop is not going into the bios mode.
A good idea would be to check the caps key which you enter the password, try it one at time.
If you entered wrong password multiple times , it won't accept the real password for much time, so you need to wait at least for 15 minutes before retrying..
Hope this helps ...:)
My hp mini will not
hi ' it does need to set it as obtain , but if you want to create an IP address click start botton-click control panel-click my network connection open network connection then right click - --- -- then click properties then type the address what you want then click sub mask and press apply/ok.
Stimy computer has the
It's either a virus or a driver problem (most likely a virus). The best solution is to get a external usb cd rom drive, and install a fresh copy of windows back onto the system to ensure no issues.
I have a HP(1010NR) mini
Reboot means to restart it. If it really "full of viruses" as you say, don't even boot it; buy a new hard drive.
I dropped my HP Mini
What that has told you is that the file pci.sys somehow got corrupted. It's possible it was being written to when the drop occurred. PCI is the bus system usually associated with hard drives and other add on devices so its not one you can ignore.
The problem and the solution are both a bit annoying. That file needs to be replaced. The easiest way would be to boot using a memory stick and then just copy a good file over. Then you have the option of doing a system restore or recovery. Unless you take it into a shop this may be your only option as you need to be able to match the file type/version etc. And it is quite possible that there are other files damaged as well. You just haven't got past the one error. The downside to this is that you may loose some documents and settings depending on how the restore or recovery version you have.
I want to restore my
If you have the restoration CD that came woth the laptop, you just have to put that CD in, start your computer and when prompted boot from cd and start the system restore.
How do i find my 25 product key
your question is vague,
but I believe your talking about the certificate for microsoft, it should be on the bottom of your notebook, or in the enclosures of your manual or cd case.
thank you
Do i need to disconnect charger for a factory restore?
NO , never,
if the big laptop , is old NONE TOLD, and that huge battery is bad as most are old, I'd remove it and run on only the AC/DC power pack
alone.
laptops PCs have to have bad huge batteries even 1 year old abused.
charger = AC/DC POWER PACK.
The charger is actually deep inside the PC> (a chip by same name)
no PC told but if you read the manual ,chapter recover, sure
it many leave out details, they assume the PC is 100% hardware prefect and is only a dream of data only geeks.
5/2/2022 11:54:23 AM •
HP Mini...
Answered
on May 02, 2022
How do we find out how to get our login information so that we can log on to the internet?
what a great question and so clear !!
well there are only 2 ways. (safe)
1: call your ISP and ask them. if they
own the router ask them.
some IPS put sticker tag bottom? of PC with credentials.
2: if however the router is
owned by you, the answer is inside YOUR router, and is covered in your Router manual, by exact model #
the 3 things to set are
- SSID (broadcasted name) I use dogs name use a name only you know so when seeing 50 others in the hood you know right away that REX123 is you.
- set encryption to WPA2
- SET WIKI PASS PHRASE TO WHAT YOU WANT, and is case sensitive...
- never use AD HOC mode or open wifi if seen.
- nor WEP
- nor WPS or PIN.
go to makers web site if router is netgear go there. get your free manual and keep it PDF.on your PC.
then read settings page.
5/1/2022 2:55:21 PM •
HP Mini...
Answered
on May 01, 2022
Vox mini laptap reset factory
hp.com
tell them pc model full, you did not.
find manual there
read it
chapter RECOVERY.
if lost ask on there forum hp.com
1/14/2022 9:59:29 PM •
HP Mini...
Answered
on Jan 14, 2022
