In the video you'll see Jared Polin (famous photographer) clean the image sensor of his Nikon D3s (not exactly the D3x, but should be mostly the same procedure).
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-D3X-Digital-Cameras-review-manual/id/23123ag309/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
By not clear do you mean out of focus or streaked due to movement? Try using a higher ISO setting in order to allow for a faster shutter speed and/or use a tripod.
You could probably use either a 1.4 x or a 2 x, depending on how much you wanted to increase the focal length of your lens. A 1.4 x would give you a range of 98-420, a 2 x would give you a range of 140-600.
Having said that, teleconverters are not usually recommended for use with zoom lenses, and you would lose one stop with the 1.4 x, two stops with the 2 x, thus necessitating longer exposures. Also, with the increase in focal length comes an increased probability of camera shake being more apparent, due to the increased magnification. In your position, I would attempt to get closer to the subject, using a teleconverter as a last resort if this is not possible.
hi,
did you charge your battery full ? if the battery is not charged enough, it will not drive the shutter opener motor perfectly, and if any type of dirt or friction on the shutter drive gears this will happen, please check the shutter movement by removing the lens.
I use GIMP 2, a free open source editor that is very sophisticated.
I think I had to install an add-on so that it would read NEF files. Gimp converts all files that are edited in it to its own "xtg" file extensions. After I finish editing, I save the picture in the "xtg" file extension then I import it in "jpg" format to the same folder where the original NEF along with the XTG formats are stored. During the editing process, I usually scale the image if I plan to send it somewhere on the web.
I think a lot of other editors have a similar function, especially if the proper codecs are installed.
In addition, in the past I have used conversion programs to do the same thing but it's been a long time. Do a web search for NEF converters and you may come up with a free program or two that will allow you to make the conversion without editing the picture.
Not sure, but if you shoot in manual mode and use manual focus the camera should still take photos. Kind of defeats the purpose of spending money on auto focus ones though. Try to turn the top dial on the camer to M (manual) see what happens?
