20 Most Recent Tomtom ONE XL 330 GPS Receiver Questions & Answers
How to format the internal memory or memory card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Welcome
    8/27/2010 7:55:24 PM • Tomtom ONE XL... • Answered on Aug 27, 2010
    When I try to format the internal memory on my
    send in to tom tom for repair
    5/10/2010 8:40:51 AM • Tomtom ONE XL... • Answered on May 10, 2010
    TOMTOM XL 325 SE Language problem
    Please view this FixYa Tip which gives a complete walkthrough on how to change the language back on your TomTom.
    If this helps, please do leave a vote for the solution.
    Thanks.
    2/11/2010 10:44:30 PM • Tomtom ONE XL... • Answered on Feb 11, 2010
    Display reads problem with map
    This means it is not reading the SD card and that it needs to be re-formatted.
    This is best done in a card reader and not the tomtom itself.
    Right click on it and select format select FAT32 as the files system
    Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
    You now ned to select your tom tom which will also show as a drive.
    In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
    It may warn you but you can ignore it.
    Then just copy ALL the files from the tom tom to your sd card
    DO NOT USE CUT AND PASTE !
    Once all the files are on switch off the tom tom and insert the sd card
    It should now work
    12/20/2009 4:14:04 PM • Tomtom ONE XL... • Answered on Dec 20, 2009
    I just bought a TomTom
    this website will show you all you nedd to know about favorites:
    www.tomtom.com/9858
    9/7/2009 3:04:54 AM • Tomtom ONE XL... • Answered on Sep 07, 2009
    Is there a way to easily get directions back to a
    I always save the location of where I am and then you can return there anytime by calling up that location.
    7/6/2009 4:47:05 AM • Tomtom ONE XL... • Answered on Jul 06, 2009
    When switched on green light next to switch flickers but that is all
    It sounds like the TomTom isn't able to boot up. This may be due to a software or data issue. Have you tried to (use HOME on your computer to) connect to the TomTom server ? to update the software/data, and/or tried to restore the software / data with the (previously) backed-up copy (that you had previously saved on your computer) ?
    10/16/2018 6:30:46 AM • Tomtom One GPS • Answered on Oct 16, 2018
    Update Installation freezes on my TomTom VIA 1500.
    hello chack this link Tom Tom wont turn on fix
    7/12/2017 2:36:51 AM • Tomtom One GPS • Answered on Jul 12, 2017
    2answers
    Approximately half an hour into trip my Tomtom one loses the map just when I need it most and I have to navigate by voice instructions only.
    Make sure there is enough power. When the power gets low, it tends to conserve by limiting items that draw the most power.
    Check if there is an option that allows the map screen to display longer.
    9/20/2016 12:39:34 PM • Tomtom One GPS • Answered on Sep 20, 2016
    How can I set time?
    You can set (or reset) your Time (& display format) using the "Menu". From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen), Look for, and tap on "Change preferences". On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
    5/19/2016 3:23:27 PM • Tomtom One GPS • Answered on May 19, 2016
    How can I set time and volume?
    These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume). From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen), Look for, and tap on "Change preferences". 1. To set Time: On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time. 2. To set Volume: On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
    5/19/2016 3:17:36 PM • Tomtom One GPS • Answered on May 19, 2016
    How do I update maps on tom tom one from computer to GPS ?
    Usually, you connect your TomTom to your computer, and use the TomTom software (e.g. HOME) to update (e.g. buy, download and install) your map(s). If your question is about how to copy a (new / another) map on your computer to your TomTom device (i.e. without using the TomTom HOME software), you can simply copy the "map" folder (of the map on your computer) to your TomTom Device (that you've connected to your computer). You may have other questions like, is there enough memory on your TomTom device for the map ?; is the (new/other) map version compatible for the TomTom (model/version) device that you have ?; is the map "activated" to run on your TomTom device? etc.
    5/2/2016 10:39:03 PM • Tomtom One GPS • Answered on May 02, 2016
    How do I get to the main menu?
    depends what tom tom you have?
    4/19/2016 6:58:08 PM • Tomtom One GPS • Answered on Apr 19, 2016
    How do i register my sat nav
    Go to the TomTom website to register your device www.tomtom.com
    4/12/2016 11:19:03 PM • Tomtom One GPS • Answered on Apr 12, 2016
    0answers
    No maps
    Be the first to answer 3/11/2016 7:50:27 AM • Tomtom One GPS • Posted on Mar 11, 2016Be the first to answer
    Tomtom ONE XL 330 GPS Receiver Logo
    Popular Tags
    14 questions posted
    Top Tomtom GPS Experts
    k24674
    Mike Cairns
    Mike Cairns
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
    View Most Popular
    One Tomtom
    • One Tomtom
    Most Popular Question
    display reads problem map
    • GPS
