20 Most Recent Frigidaire fex831cs stacked washer&dryer 220 volts Questions & Answers
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Frigidaire... | Answered on Apr 27, 2016
solenoid valve is probably faulty, it is usualy located at the top of the machine close to the drawer
Frigidaire... | Answered on Jan 24, 2015
first try moving your drain hose higher it can cause this problem
Frigidaire... | Answered on Oct 04, 2019
Unplug it for 5 minutes. If that doesn't work, you may need to empty it of water by lowering the drain hose into a pail lower that the door.
Frigidaire... | Answered on Sep 14, 2019
Hello Deena,
Error Code e21
means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
  1. Pull the machine out from the wall.
  2. Then take the panel out in the rear. Once the panel is off you will see the drain pump.
  3. Disconnect the drain Tube between the Tub and the Pump.
  4. Look inside the pipe you will find the Drain Filter.
  5. Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
  6. Try a full cycle.
That should end your problem.
Best of Luck!
JP
Frigidaire... | Answered on Aug 31, 2019
Try going to another setting on the dial like heavy or delicate and spin the dial from start and click to almost the end of wash cycle and start. the pump should start draining. If not your may have to go a few clicks less or more just spin around again. If it does not pump out then it could be a clogged drain line or bad pump
Mike .
Frigidaire... | Answered on Aug 25, 2019
Frigidaire fex831cs stacked washer&dryer 220 volts Logo
2 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
washer squeaks during agitation both
  • Washing Machines
