20 Most Recent
SkyGolf SkyCaddie SG2 GPS Receiver Questions & Answers
I RECENTLY PURCHASED A NEW
If your SkyGolf came with software, you should install it first. If you installed it and it does not work, go to the software and check for updates.
If that fails to work, UNINSTALL the program, and re-install it.
Make sure you DO NOT connect the device to the computer until the software is fully installed.
Check for updates after installation, and the reboot.
Then attach your device to the computer, and it should recognize it.
Good luck
7/10/2011 2:51:24 AM •
SkyGolf...
Answered
on Jul 10, 2011
Unit taking long time to establish satellite
5-7 mins is not unusual in many cases. Battery condition has a lot to do with the time it takes to establish connection. Recharge or replkace batteries with better quality ones and keep well charged up if you use rechargeable ones
12/1/2010 11:23:10 PM •
SkyGolf...
Answered
on Dec 01, 2010
I need a PC SERIAL
Hi.
SG is no longer manufacturing this but you can try a generic PC serial cable ( db9 to 2.5 mm jack) from
M2 cables or local radio shack.
Hope this helps.
11/22/2010 10:19:19 PM •
SkyGolf...
Answered
on Nov 22, 2010
I just gought a SG2
You can download the operator manual in PDF format by clicking this
link. Adobe PDF Reader is required to view this manual.
Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using
FixYa.
10/3/2010 5:24:00 PM •
SkyGolf...
Answered
on Oct 03, 2010
My skycaddie was immersed in water. Battery
if the device got wet while the power was on` it most likely shorted out components in the device and you will need a new one. if its worth your time and money you can try purchasing a new battery, but chances are the device still has water inside and is shorting it still. dis assembly and inspection of inside cavity is the only way to guarantee that it really is DRY completely, but is illogical to try to take these devices apart ~ electronics dropped in water have to pretty much be called defective after immersed.
sorry .thats probably the wrong answer. but its 100% truth
7/31/2010 4:50:58 PM •
SkyGolf...
Answered
on Jul 31, 2010
Trying to renew my membership , but your site hides the moves .
There is no problem with this as such, all you need to do is sign in and go to terms, under the terms, screw down, you will see subscription program, read the details there in very well, during your reading, you will see two places in capital letters that reads CLICK HERE, you can use the second one to cancel your subscription and re-register as a new customer or the first one to change your payment information.
But i advice you use the second one to cancel and re-register so that you can fill in the necessary thing you want to modify.
Take care
5/19/2010 1:19:51 AM •
SkyGolf...
Answered
on May 19, 2010
Missing driver disk for my Skycaddie SG2
I can't tell you how I solved my problem, because then I would have to charge you, like you want/wanted to charge me to solve it. Sorry, maybe if you were more willing to help, I would be more willing to share.
1/15/2010 3:17:02 AM •
SkyGolf...
Answered
on Jan 15, 2010
