20 Most Recent Brandt WFH1176 Front Load Washer Questions & Answers
How to operate top loader brandt malice AA washing
Hi guys! Please help me. I used the Brandt Malice top loader with a horizontal drum. I don't think the doors on the drum were clipped closed properly and now when I open the machine the drum is not facing up so I can't open it? It also won't spin. What do I do? There is clothes in there and the machine is off, but the drum seems stuck? Please help!
9/19/2017 6:12:06 AM • Brandt WFH1176... • Answered on Sep 19, 2017
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
8/14/2016 7:23:35 AM • Brandt WFH1176... • Answered on Aug 14, 2016
Brandt hob two induction and two gas one of the electrodes for ignition is damaged is it possible to fit a new one
upload the image from where it was broken ?
12/31/2014 6:05:23 PM • Brandt WFH1176... • Answered on Dec 31, 2014
How to operate the washing
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    4/5/2013 5:13:28 PM • Brandt WFH1176... • Answered on Apr 05, 2013
    2answers
    Hi, My brandt washing machine suddenly have a
    Please help me my brandt wfd711a stop running and comes out error F02. any suggestions?
    1/9/2012 2:40:50 AM • Brandt WFH1176... • Answered on Jan 09, 2012
    Cycle #6 take 2 hours, is this normal ? Pls give
    Sorry but this forum does not supply telephone numbers for service engineers; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
    You will either need to look in your telephone directory yourself (sorry again!) or find a suitable place from on the web. We would not be in a position to suggest service engineers.
    Good luck,
    John C
    2/24/2011 3:53:02 PM • Brandt WFH1176... • Answered on Feb 24, 2011
    My kleenmaid brandt 5kg washing machine has had a
    hi dyan, are you based in australia? whome did you get to fix your machine? have you solved the issue now?
    my mum has the same machine (which she loves) and hers has just stopped working and she was interested to know more about your post and issues you have experienced.
    cheers
    kelly
    4/22/2010 7:05:05 AM • Brandt WFH1176... • Answered on Apr 22, 2010
    After completing a wash, the softener compartment
    you can open top cover, remove hose from softner compartment and clean the hole.
    11/3/2009 3:36:46 AM • Brandt WFH1176... • Answered on Nov 03, 2009
    2answers
    How to fix error code 43 in brandt edge band machine ???
    Open the middle door on the back and you'll see one dial type breaker turned horizontal while the others all face vertical. Turn it back up and it'll reset the breaker.
    2/29/2024 8:37:47 AM • Brandt Washing... • Answered on Feb 29, 2024
    2answers
    Hi What's the problem error 44 In edgebander brandt 56?
    https://www.youtube.com/watch?v=ZV1nmf6bal8 https://www.youtube.com/watch?v=YoHobUwOYJU
    11/8/2023 8:42:35 PM • Brandt Washing... • Answered on Nov 08, 2023
    Brandt WFH1176 Front Load Washer Logo
    29 questions posted
    Top Brandt Washing Machines Experts
    NOEL
    NOEL
    ADMIN Andrew
    ADMIN Andrew
    Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
    View Most Popular
    • Brandt Washing Machines
    Most Popular Question
    • Washing Machines
