20 Most Recent Fisher and Paykel WL26CW1 Top Load Washer Questions & Answers
All replaced electronic boards need resizing.
Going by your post your have an AquaSmart machine
Here are some details to resize an AquaSmart machine
Fisher and... | Answered on May 02, 2018
if it was left switch on at the wall when the power came on again it probably blew the computer board due a current surge
Fisher and... | Answered on Mar 02, 2018
this is usuallt the R.P.S which is locked on the motor take off plastic cover by un doing centre nut loosen stator pull forward a little and remove stator
Fisher and... | Answered on Oct 26, 2017
With the board replacement, did you program this board for this unit? If not, thats the problem you have now. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Fisher and... | Answered on Feb 02, 2016
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Fisher and... | Answered on Sep 14, 2014
Fault 9 LAH HIGH CURRENT FAULT The low ambient heater is drawing more current than expected. Either the heater or wiring is faulty.
Primary Action
- Check the wring and connections at both heater and power module.
Secondary Action
- Check heater resistance. If not within limits replace heater.
Fisher and... | Answered on Aug 15, 2014
whaat model do you have? there a few slightly different things you can do. most common is hold start, press power. then power off. and back on.
Call the factory 888-936-7872, they can help you over the phone. 24/7, they are always willing to help. You may need to re-program this board. Good Luck
Fisher and... | Answered on Aug 04, 2014
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Fisher and... | Answered on May 20, 2014
Might need to clean the sensor. Run through a rince cycle without clothes in it
Fisher and... | Answered on Apr 26, 2014
If the plug is fused then the fuse should blow before an appliance catches fire. If you go here they have a great customer service base and can recommend an authorised agent to look at and repair your machine if needed. If you want a manual they can also supply you with one just to make you more confident about the operation of your machine.http://www.fisherpaykel.com/us/laundry/?productUid=49343ABD-C773-932B-26D02C8672FC7E2B
Fisher and... | Answered on Mar 11, 2014
Fisher and Paykel WL26CW1 Top Load Washer Logo
56 questions posted
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Washing Machines
Most Popular Question
fisher amp paykel wl26cw1 error code
  • Washing Machines
