20 Most Recent
HP C6280 All-in-One Printer Questions & Answers
Stopped printing yellow
Out of yellow ink?
If your ink is full, then you most likely have a dried up yellow ink path or the sponge at the bottom of the printer is full and preventing ink to pass through to the paper. Chances are, you are plugged up and need a new printer - HP is water based and if not used on a constant bases, the ink will dry and cause clogging. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/william_02fc2766c1e13b73
8/5/2014 8:08:25 PM •
HP C6280...
Answered
on Aug 05, 2014
Replace scanner bulb
Ok what is the issue.. are you not able to replace it or you are not able to remove it.
11/7/2013 2:44:53 PM •
HP C6280...
Answered
on Nov 07, 2013
PRINT INK CARTRIDGE ALIGNMENT FAILED HP C6280
Hi,If the alignment failed on HP Photosmart C6280, Try to check if any of the cartridges are low on ink. if so replace them and try to re-alignIf that is not the issue, Remove the Cartridges from the printer and clean the contacts with lint free cloth and put them back in. The printer should go thru auto - alignment..If this fails too, Press Cancel button on printer and Press the Menu button ( setup button ) and scroll to Tools menu - Press OK - Under tools option you will find Clean Cartridges - Press OK.If this process too does not fix the issue, mostly likely your printer has gone bad. It needs replacement.The best i can suggest you will be to Call HP support - 1-800-474-6836 and check best deal they can offer you on upgrade printer.Regards,Suhail
5/20/2012 11:56:15 PM •
HP C6280...
Answered
on May 20, 2012
Ink system has failed unabel to print refer to
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate
good day
6/16/2011 3:51:34 AM •
HP C6280...
Answered
on Jun 16, 2011
HP PRINTER C6280 problem says ink system failure
Reset the printer:
With the product turned on
, disconnect the power cord from the rear of the product.
Wait at least 15 seconds.
Reconnect the power cord to the rear of the product
Remove, clean, and reinstall the printhead
remove ink cartridges
Figure 22: Lift the latch handleLift the printhead straight up to remove it.
Figure 24: Three areas to clean
1 - Plastic ramp on the side of the ink nozzles
Figure 29: Clean the electrical contacts inside the product
Dry the area with a clean, dry, lint-free cloth.
Reinstall the Printheads and the cartridges
Reset the product
It should work otherwise try to replace the Printhead and instead change the entire printer its time to change it
5/6/2011 7:33:49 AM •
HP C6280...
Answered
on May 06, 2011
