20 Most Recent LG BD610 BRay Disc Player Questions & Answers
Won't read regular dvd's
I think local disc cannot read your DVD. Put quality disc into your DVD.
2/28/2019 12:49:06 AM • LG BD610 BRay... • Answered on Feb 28, 2019
Usb on bd610 lg won't work
I don't understand this term: "choose either dvd or usb menu". Do you mean instead ""choose either dvd or cd menu? I've used many usb hard drives and I've never seen such a "menu".
5/17/2014 8:05:27 PM • LG BD610 BRay... • Answered on May 17, 2014
Hello. How to set the LG DVD/CD RECEIVER LH-D6230 to the AUX mode if you have lost the remote control. Can it be done manually.
You can't. You need a remote.
Replacement remote control for LG LH-D6230
Remotes World https://remotes-world.com > LG Replacement remote control for LG LH-D6230 with all functions of original one. It replace each button of original remote control. You will receive it with ...
3/13/2024 11:40:59 PM • LG Audio Players... • Answered on Mar 13, 2024
How to remove D Protect from LG CJ45
1/24/2024 12:41:20 PM • LG Audio Players... • Answered on Jan 24, 2024
LG FB162 no sound when connected with Aux
Instead of aux (Blue Connector of PC Sound), try using head phone jack (Green Connector of PC Sound). It if is working fine, uninstall sound driver of your PC, restart PC and install sound driver again. Your problem will be fixed.
12/14/2023 2:41:16 PM • LG Audio Players... • Answered on Dec 14, 2023
How do I reset my LG LHB 625
To reset your LG LHB 625, follow these steps: Turn off the device and unplug it from the power source. Wait for a few minutes and then plug it back in. Press and hold the STOP button on the front panel of the device for at least five seconds. The display will show "INIT" and the device will reset to its factory settings. LG LHB625 Product Support :Manuals, Warranty & More ' LG U.A.E.
11/4/2023 10:38:14 AM • LG Audio Players... • Answered on Nov 04, 2023
Audio not working on VCR side of LG LRY-517 DVD/VCR combo player
The back of the lry517 has 2 sets of audio outs and 1 set of audio ins. If you are using the component video outs, use the audio outs to the right of the component outs. If you are using AV1, it should be the audio to the left of the component outs. The tape's audio may be very low, try turning up the tv volume? You could also try adjusting the tracking? Have you tried using the AV1 outputs? It would be Composite Video and stereo audio.
4/25/2023 4:29:49 AM • LG Audio Players... • Answered on Apr 25, 2023
2answers
Remote control code for LG
2/14/2023 5:45:07 AM • LG Audio Players... • Answered on Feb 14, 2023
I have a “please wait” problem in my lg home theatre (model hb906sb) ??
The "please wait" problem in your LG home theatre (model HB906SB) is likely an issue with the system's firmware or software. Try unplugging the system from the power source for a few minutes, then plugging it back in and turning it on. If the issue persists, try performing a factory reset of the system. If none of these solutions work, contact LG customer support for further assistance.
2/14/2023 5:36:07 AM • LG Audio Players... • Answered on Feb 14, 2023
2answers
How can I unlock a LG HT LHD625 to play DTS? The HT's Display recognize DTS but that is no sound.
It is not possible to unlock a LG HT LHD625 to play DTS if it does not support DTS decoding. The display may recognize the DTS signal, but if the HT does not have the necessary hardware and software to decode the DTS signal, it will not be able to produce any sound. You may need to use a different audio format or upgrade your HT to a model that supports DTS decoding.
2/14/2023 5:34:50 AM • LG Audio Players... • Answered on Feb 14, 2023
LG DVD Receiver HT552TH is not switching from DVD to AUX or Band. What to do?
Here are some steps you can try to troubleshoot the issue with your LG DVD Receiver HT552TH:
  1. Make sure that the AUX or Band input is properly connected to the receiver.
  2. Try resetting the receiver to its default settings by unplugging it from the power source, waiting for a few minutes, and then plugging it back in.
  3. Check the input settings on the receiver and make sure that the correct input is selected for the AUX or Band.
  4. Try using a different remote to see if the issue is with the remote or the receiver.
  5. If the issue persists, it may be a hardware problem with the receiver, and you may need to contact LG customer support or take it to a professional repair service.
2/14/2023 5:23:08 AM • LG Audio Players... • Answered on Feb 14, 2023
I have a LG Tribute HD. There is no option for central standard time zone anywhere. Both the network automatic time and the manual time zone s ard wrong.. I live in Topeka Ks which Time zone do I use...
Topeka, Kansas is in the Central Time Zone (CT). Therefore, you should select the "Central Time" or "CT" time zone option in your phone's settings to ensure that the time displayed on your phone is accurate for your location. If you are unable to find this option on your LG Tribute HD, you may want to try updating your phone's software or contacting LG customer support for assistance.
2/14/2023 5:19:10 AM • LG Audio Players... • Answered on Feb 14, 2023
Wat is s- protection on my lg home theater systerm
I'm not sure what specific LG home theater system you are referring to, but "S-Protect" is a feature found on some LG home theater systems that is designed to protect the system from damage due to power fluctuations or speaker wire issues. When the system detects a potential problem, it will automatically shut down to prevent further damage.
2/14/2023 5:14:06 AM • LG Audio Players... • Answered on Feb 14, 2023
My LG home theater doesn't want to turn on,tried it manually and with remote but still,what could be the problem
Could either be an issue with the power supply or there's a short in the main power amp section. You should check all speaker connections and cables and the speakers themselves. Any wiring touching each other or a faulty speaker can cause an overload thus activating the safety features in the unit.
12/29/2022 5:38:03 PM • LG Audio Players... • Answered on Dec 29, 2022
I have a LG 780 head and the sound went out in the speakers is the someone who can fix them
The wires and the audio amplifier are not working for your speakers and it would be more cheaper and easier to buy new speakers then to try and repair the speakers that are broken.
12/24/2022 7:35:56 AM • LG Audio Players... • Answered on Dec 24, 2022
2answers
LG ' LH-T550TB
Your question ............................. is ..................................
12/7/2022 6:50:52 AM • LG Audio Players... • Answered on Dec 07, 2022
2answers
My LG Home Theater is Stuck on Please Wait. How do i fix it
did you try unplugging it, waiting 30 seconds, and plugging it back in?
12/4/2022 11:57:23 AM • LG Audio Players... • Answered on Dec 04, 2022
My lg mini hifi system displays s-protection then switches itself off
it could be a faulty component around the output amplifier or any short circuit on speaker wiring.try to disconnect speakers if still displays the same warning,take it to a qualified technician.
11/10/2022 4:38:50 PM • LG Audio Players... • Answered on Nov 10, 2022
Thunder strike enter my LG AUD 675LHD and is not working anymore, it shutting down my Generator once I plug it.
You mean 'lightning strike'. Thunder is the noise. You will need professional diagnosis to what parts were destroyed by the voltage surge. If you are lucky, it will only be the power supply, if you aren't, it will be every component damaged.
10/16/2022 9:38:29 PM • LG Audio Players... • Answered on Oct 16, 2022
LG BD610 BRay Disc Player Logo
3 questions posted
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • LG Audio Players & Recorders
Most Popular Question
usb bd610 lg won 39 t work
  • Audio Players & Recorders
