20 Most Recent
Sony VAIO VGN-NS110E/L Notebook PC Questions & Answers
How to capture picture on
Hi s_farah07,
You can use the WebCam Companion Software installed in the Computer to capture images using the Motion Eye Camera.
To locate the Application, please click
Start, All Programs, ArcSoft WebCam Companion Software and click
ArcSoft WebCam Companion. This will open the Appilcation, then you can click the
"Capture" option to capture the images.
If the Applications is not available in the Computer, you can download and install it from the below link.
http://s02.download.sony.com/US/pc/SOAVCU-15458700-US.EXE
Hope this helps.
Please let me know if you have any questions or require any further assistance.
Thanks for using FixYa.
11/14/2012 11:26:25 PM •
Sony VAIO...
Answered
on Nov 14, 2012
Restore factor settings on sony vaio VGN-NS110E
Click the Windows "Start" menu.
2-Click the "Help and Support."
3-Select the "Vaio Recovery Wizard" option.
4-The Vaio Recovery Wizard will launch. Follow the
instructions given as you advance through the wizard. When prompted,
confirm that you want to reset your Vaio to its original factory
settings.
5-Allow the computer about an hour to properly restore itself to factory settings.
4/12/2012 5:46:33 AM •
Sony VAIO...
Answered
on Apr 12, 2012
Computer freezing up running slow VAIO VGN-NS110E
1. stop those unnecessary start-up programs which will affect computer boot time a lot.
2. do a disk defragment or a registry defragment. the former will free up your disk space, and the latter will give a clean registry.
3. notice that just cleaning up registry is not enough. you should fix registry errors.Registry is so important to a computer, so if you are unfamiliar with it ,do not delete anything by yourself, or your computer will collapse.
you can go http://www.ccleaner.com to download a registry cleaner. it will help to scan registry.
and then go http://www.system-tools-software.com/free-registry-defrag/ to download a totally
free registry defrag to clean up your registry thoroughly.Both they are free.
4. remove all junk files and history.
5.fully scan your computer. Virus always cause a computer slow down. At the same time, you should also know that using more than 1 antivirus software is harm to your computer. They will make a big confliction by uncompatible with each other.
6. Add some RAM, which is helpful to computer speed.
7. if all above do not work, you may consider to do a reinstall of Windows. Before you do it , please remember to back up all your important files.
Everyone hates slow computer, do something and make it fast again.
Good luck to you.
7/5/2011 5:39:59 AM •
Sony VAIO...
Answered
on Jul 05, 2011
I cant use my laptop
hi..
- first install the web cam software..
- if it not comes means check your hardware or your web cam..
- thank u..
- If it's useful for you means plz rate me the 4 Thumbs ....
2/8/2011 2:52:28 PM •
Sony VAIO...
Answered
on Feb 08, 2011
I have a sony vaio VGN-CR42s/b and recently it
check your control panel to see what programs are installed, Too many programs installed can slow your computer, also check your security to see if your taking up too much space, also google chrome is one of the fastest but this will not help with start up. Delete any unused programs and compress all your files.
2/15/2010 1:58:00 PM •
Sony VAIO...
Answered
on Feb 15, 2010
Broken key.
hi notesticky i once had a problem simlar to this one i was replacing a keyboard to laptop when a key pop-out what i did was to snap back key in place, on the keyboard layout has rigids that snap each key in place but if it's broken you might have to replace keyboard section. you can find a replace keyboard at ebay.com and don't forget put model # maker of laptop. good luck.
5/25/2009 4:36:15 AM •
Sony VAIO...
Answered
on May 25, 2009
Laptop gives off a high pitched screech ONLY upon start ups
Assure there a no disks in your CD/DVD drive
Make sure there is nothing blocking the fan
Feel the base of you laptop and assure it is cool
Do not block off air flow
Event Viewer: Click the Start button . In the Search box, type
Event Viewer, and then, in the list of results, double-click Event
Viewer.
Go to the Sytem Tab - Look for any errors that seem noteworthy
Post your results
1/7/2009 8:58:53 AM •
Sony VAIO...
Answered
on Jan 07, 2009
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
