20 Most Recent
Gateway MT6840 Notebook Questions & Answers
How do I recover files after attacked by dulla
use this file recovery program named asoftech data recovery to scan your computer and then recover your files.
http://www.asoftech.com/adr/ This software scans all storage space and then join pieces together to recover files. So even virus affected your file table, and put virus to boot sector, the program can still be used to recover your files.
Burtton
you must open the computer. If you have the owner manual or literature coming with the computer do it and follow the step. otherwise you can download the instrus manual from your computer supply from the website.Otherwise you must go to the repair shop .God bless you
Is there a docking station for my mt6840 gateway computer?
I do not believe there is a docking station for that model. But...
Try pulling out the battery. Then plug in the power supply and see if you can get it to power on. If so wiggle the plug and see if it shuts off. If either if those are true, en you most likely need your DC Jack replaced. You would want to take it to a laptop repair shop. It is usually $20 for the part and around 1.5 - 2 hours labor for the repair. Requires pulling out the motherboard and desoldering the old jack. And soldering in a new one. No fun
Doesnt stat up and no light showing charge
Here's one way to determine the problem.
Take the battery out and try to boot on AC power only, if it boots turn it back off, reinsert the battery again and try to boot.
Sometimes you just have to take the battery out and plug it back in again, with others it is the battery and you have to leave then out until a replacement is bought.
If it still won't boot on AC only, remove and reinsert the memory, try to boot the computer and listen for any beeps.
Post back if you need further assistance.
Good luck.
Need to find passwords used found them on another
I assume you're trying to view the passwords used in the Firefox browser on one computer, so that you can enter that information into a second computer. (If that's not correct, please let me know.)
There are several ways to view stored passwords::
(1) Use Firefox's built-in password viewer. In the browser, go to:
Tools > Options > Security > Saved PasswordsThen click on "
Show Passwords"
(2) Use 3rd party software to retrieve the information from Firefox. Here are two suggestions for free software -- you can use either one.
PasswordFox by Nirsoft. See
http://www.nirsoft.net/utils/passwordfox.html--
FirePasswordViewer by SecurityXPloded See
http://www.securityxploded.com/firepasswordviewer.phpYou would need to install the software on the computer where the passwords are stored.
25 character of product key for a gateway
Your product key is on a sticker on the bottom of your comp. You can also download a free key revealer which will search for and tell you your key. If you want to know more, just let me know.
