20 Most Recent Lenovo 3000 N200 Intel Pentium Dual Core T2390 1.86GHz Notebook Laptops Questions & Answers
I want software of Web
merhabalar benim sorunum webcam kamera ile ilgili lenovo 3000n200 769 a24 webcam kamerayı bulamadım bu kadar uğraşacağmı bilseydim almazdım laptopu nerden bulabilirim bana yardımcı olursanız sevinirim [email protected] hoşça kalın
12/26/2016 8:05:27 AM • Lenovo 3000 N200... • Answered on Dec 26, 2016
My icons changed in to kmp player, how can i change it back ,i cant able to open tht if i try to open tht it display tht it is a corraupted file
Right click on file, i.e. your WORD doc file, select "open with", select "open with program" at end of listing, even if WORD appears, from the listing select WORD and checkmark where ir say "use always this program to open files". Repeat for each extension to updated correct associationAnother way might be Restore System to a point before this mismatch happened
10/3/2015 1:20:17 PM • Lenovo 3000 N200... • Answered on Oct 03, 2015
I need to know where to get WIFI driver for this Laptop
look towards the bottom for wireless lan driver and choose the one you need. Laptops and netbooks Lenovo Series laptops 3000 N200 Notebook Lenovo...
4/1/2015 7:21:56 AM • Lenovo 3000 N200... • Answered on Apr 01, 2015
0answers
Wireless radio off
Check the Device driver for the wireless card. If it is not installed the install the wireless card driver. The same model Lenovo can have different types of network, video and audio drivers and unless you know exactly which one is installed in your Lenovo, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
11/20/2012 6:29:56 AM • Lenovo 3000 N200... • Answered on Nov 20, 2012
Audio drivers
Try re-installing the audio driver. The same model Lenovo can have different types of network, video and audio drivers and unless you know exactly which one is installed in your Lenovo, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
11/18/2012 10:43:46 AM • Lenovo 3000 N200... • Answered on Nov 18, 2012
Plugged in, not charging
there are 3 points of failure here, one is the battery so if you can try a known good battery then we'll be able to check if that's whats causing the problem.
The 2nd point of failure is the adapter it could be not giving enough output causing the battery not to charge. Try a different charger and see if that will work for you.
3rd point of failure would be a very bad news because it's the port where you plug the charger in the laptop as that would mean replacing the motherboard.
One thing you can try though but you would have to proceed at your own risk, is to flash the BIOS.
Download the latest bios from the support site of your computer manufacturer and after flashing see if there will be any changes. If none then there is a hardware problem with either one of the three I mentioned earlier.
Hope this helps!
9/2/2011 2:58:01 PM • Lenovo 3000 N200... • Answered on Sep 02, 2011
I press the power button, CPU fan comes on for a
Welcome to Fixya
Sound like LCD problem. Try to drain the electorstatic charge of the board for this sometimes the cause of no display while computer is turned on. I wrote a tip on how to do this. Please click here.
If this will not work then you have a bad LCD there and needs to be repaired.
Please let me know if you have further questions.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
9/1/2011 9:15:46 PM • Lenovo 3000 N200... • Answered on Sep 01, 2011
When i format my lenovo laptop i entered the
Hi wael,
I see that you installed Win7 on your Lenovo but you are getting a recovery page when you got it started up.
It shows that Windows 7 did not install properly or may have encountered an error during the installation of Win7, try reinstalling Windows7 again or just run the recovery on the machine and insert the disc if the system asks for the disc to be inserted cause it may need some files to fix what ever error it may have experienced.
I hope this helps.
Have a nice day
mvincentc
5/14/2011 2:53:53 AM • Lenovo 3000 N200... • Answered on May 14, 2011
Me screen keeps black allthough the computer is on
Try doing a power drain.
1. Turn computer off by pressing the power button for about 5 seconds.
2. Take the battery out.
3. Unplug the ac adapter.
4. Press and hold the power button for about 15 seconds.
5. Put everything back in.
6. Turn the compuer back on.
there goes your display back. Thank you for visiting FixYa!
4/23/2011 4:38:21 PM • Lenovo 3000 N200... • Answered on Apr 23, 2011
HI. I just bought my
it will need tobe configort get with you IP provider. Or if you have a wireless router THAT will need tobe config with your LP
4/17/2011 7:13:31 AM • Lenovo 3000 N200... • Answered on Apr 17, 2011
My Laptop is Lenovo 3000
Sir please follow the link below to get the latest drivers for youe laptop and after the installation please try to update them once http://www-307.ibm.com/pc/support/site.wss/MIGR-67855.html
4/10/2011 2:03:51 PM • Lenovo 3000 N200... • Answered on Apr 10, 2011
2answers
KEYBOARD NOT FULLY WORKING SOME KEYS ARE WORKING
specify your complete problem what do you mean by my acer laptop is clicking ....
have you problem with your laptop power or OS failure??
check for warranty ..sometimes this happens cause of the voltage problem in your arrea??? check your charger for this
my second openion is
board is X3100 rite .. now check the RAM is it inserted properly , then check for the processor .. unplug it from frame and then insert again check if its not burned .. the chip on its upper level will be shinning and new if it isn't , if it is dark and burn-y type then your processor is out , there is always a power bulb in mother board,,, if it is on when you turn the laptop on then your main board is OK . and if its not then out of work .. sorry for that i am a professional at boards but sometime if you don't see a thing for your self ,things don't work,,,, it is this way ,no matter how much i try if you don't explain the things right to me i wont be able to figure it out . more over have you tried to plug it by VGA cable to a monitor or LCD..
about your issue first of all i wonder that Was the adapter you bought directly from Lenovo? I just know that dell builds in a chip to detect the adapter, some other adapter might work but it will burn down the board after quite some time . may be your another lap top didnt spend much time on that adapter ,
secondly
have you tried troubleshooting following steps , that may help resolve minor issues,
1. No LCD display but unit is actually powered ON
2. Laptop battery not charging
3. Keyboard not responding
4. windows no boot issue
here is answer to these all : take out the battery and unplugged the power adapter. press and hold the power button for 30 secs then release after 30secs. put the battery/adapter back in. issue above should be resolved. if fails, contact your computer's manufacturer thats the least i want to say , which is the first post i am not willing to say so for you i wish i could have helped.???
my second openion to you is I would say your laptop lcd and other parts are fine it is a mother board you require.
If you browse ebay there are lots to choose from at different prices. It is a straightforward job to replace .:)
4/4/2011 9:24:18 PM • Lenovo 3000 N200... • Answered on Apr 04, 2011
Dear How r u Please Send
You can download the drivers here - click this link
Hope this help. Goodluck!
3/28/2011 4:46:04 AM • Lenovo 3000 N200... • Answered on Mar 28, 2011
Cannot enable external display or
right click on desktop and you have 2 ways to go
1. properties, display settings, advanced and enable clone display
2.setup display on netbook and monitor
DEPENDING ON YOUR OPERATING SYSTEMS, USE 1 OR 2
IF THE SOLUTION IS GOOD FOR YOU, PLEASE VOTE!
3/26/2011 4:39:02 PM • Lenovo 3000 N200... • Answered on Mar 26, 2011
3answers
VISTA product key
just download the patch of your vista and install them your key will be activated. And if you wish key the go to serials.ws and find your key....okay
11/14/2010 2:48:50 PM • Lenovo 3000 N200... • Answered on Nov 14, 2010
I whant free sound and volume card its not working
Normal 0
The same model ThinkPad can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the drivers and install each driver until you find the right driver.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link: -
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a sub folder on C:\drivers Then install the various drivers from this folder (run the set-up file).
10/16/2010 6:14:51 AM • Lenovo 3000 N200... • Answered on Oct 16, 2010
Audio not working saying no volume card
Normal 0
10/16/2010 6:13:17 AM • Lenovo 3000 N200... • Answered on Oct 16, 2010
Lenovo 3000 N200 Intel Pentium Dual Core T2390 1.86GHz Notebook Laptops  Logo
Popular Tags
68 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
3000 Lenovo
  • 3000 Lenovo
Most Popular Question
keyboard not fully working some keys
  • Computers & Internet
