20 Most Recent
Sony VAIO FW Series VGNFW275JH Questions & Answers
Power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
My sony laptop power jack
This is a common problem, and the solution is not cheap or easy. The connector is soldered to the motherboard, or sometimes to a smaller auxiliary board. Either way, taking apart a laptop is not easy. This is a fix usually recommended for a computer shop. Sometimes it is not repairable, and a new circuit board is needed.
My wireless is not working after doing an
Most probably, what happened was that the Anti-virus identified the wifi as a threat and blocked it. try to install the driver for the wifi again and see if that helps. Make sure that you have a firewall set (through the windows security center)
My Sony VAIO's wireless switch doesnt wanna
Try to go to another place where there is free WIFI like Starbucks or similar place.
If the computer can connect there, the the problem is with the WEP KEY on your modem/router. You need to update this key on your computer's wireless connections.
We need to know what operating systems do you have and what kind of modem/router do you have to help you more.
My laptop powers on and I can hear the fan but
Reseat the memory one stick at a time in each slot one at a time. After each reseat turn on the laptop and see if you get video. If after doing each memory stick you don't get video then go ahead and take out the hard drive and then take out the dvd drive.
If after doing this you still don't get video then the motherboard is bad and would need to be replaced.
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
