20 Most Recent Acer Extensa 4620-4648 Notebook Questions & Answers
you can try using windows system restore : Which restores your machine to an earlier date.
Start : Programs : Accesories : System tools : System restore.
Thanks,
Fame !
Acer Extensa... | Answered on Feb 10, 2019
That laptop is very old. If this is running windows, and you have been running the latest windows updates like you should, then it really isn't powerful enough for today's stuff. You could find a fine re-manufactured laptop running windows for $250.
Acer Extensa... | Answered on May 21, 2017
http://global-download.acer.com/GDFiles%5CDriver/Audio/Audio_Realtek_6.0.1.5543_Vistax86.zip?acerid=633639019537281564 - donload the audio drivers and install them
If helped rate fixya
Acer Extensa... | Answered on Apr 29, 2013
Lost Windows password:
  • Log in as Administrator (try safe mode if you don't see Administrator).
  • Login as other user (if other user is availible) and manage users.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Acer Extensa... | Answered on Aug 30, 2012
You have to find the person that put the Hard Drive Password on. I'm not saying you stole the laptop, but 99% of the time if a person has a laptop and does not know the hard drive password, the laptop is stolen. The original Owner put the password on the hard drive to keep thieves from getting to sensitive data. It could have been set remotely by the original owner if the laptop i stolen.
Acer Extensa... | Answered on May 06, 2012
have to update firmware in web cam
thank you
servicemanualboy@gmail.com
Acer Extensa... | Answered on Jan 05, 2012
Hi chubico04...
Try this solution to your problem.
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Acer Extensa... | Answered on Sep 27, 2011
get the screen replaced
Acer Extensa... | Answered on Jun 17, 2011
Take the battery out, leave the machine on the AC power and try again.
Acer Extensa... | Answered on Feb 05, 2011
Please check your OS and HDD for malfunction. Re install the OS if needed and replace HDD if defcetive
Acer Extensa... | Answered on Jan 24, 2011
Check out ebay. There is usually plenty of choice on that site.
Acer Extensa... | Answered on Jan 14, 2011
the main problem why blue screen comes is that if u install a new software and it is not compatible or some software goes wrong.the best way to tackle with blue screen is go to safe mode and uninstall the freshly installed software or programee
Acer Extensa... | Answered on Jan 05, 2011
Hello
This is what you should do;
Press Alt+ F10 at the first Acer Screen you see when you power the unit on. or when you are in windows it is accessed through Start> Acer Empowering Technology Folder>Acer Erecovery Manager. it will prompt you to create a password after that click Restore at the bottom and choose Restore to Factory Default and confirm by clicking OK.
make sure the unit stays plugged in the entire time it will run about 15-20 minutes and show you a Copying From Partition screen and a loading bar while it processes.
Please note that this will overwrite C:
Acer Extensa... | Answered on Dec 11, 2010
THIS IS A LIST OF DEFAULT BACKDOOR PASSWORDS FOR VARIOUS MANUFACURERS OF BIOS MANUFACTURERS.
Award BIOS backdoor passwords:ALFAROME BIOSTAR KDD ZAAADA
ALLy CONCAT Lkwpeter ZBAAACA
aLLy CONDO LKWPETER ZJAAADC
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
AWARD PW j332 TTPTHA
AWKWARD j322
awkward
AMI BIOS Backdoor Passwords:AMI BIOS PASSWORD HEWITT RAND
AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
IF THIS DOESN'T WORK, YOU CAN DOWNOAD AND BURN THE ISO FOR "HIREN'S BOOT CD" THIS LIVE CD WILL FIX MOST ANYTHING AND HA AT LEAST 2 PROGRAMS FOR CLEARING BIOS PASSWORDS. IT'S FREE HERE:
http://hotfile.com/dl/61282591/7ac32e4/Hirens.BootCD.11.0__9Down.COM.rar.html
USE THE "REGULAR" DOWNLOAD OPTION. TAKES ABOUT 45 MINUTES BUT WELL WORTH THE TIME.
GOOD LUCK AND IF I HAVE HELPED YOU PLEASE CONSIDER GIVING A GOOD RATING. THANKS
Acer Extensa... | Answered on Oct 19, 2010
You can set your computer back to factory settings. To do so:
Turn Off the computer; now hit the power button,, as soon as you hit the power button press ALT key and then tap F10 key (i.e ALT+F10); this will come up with the recovery screen, select full system restore or Factory restore and follow onscreen instructions.
Thanks and regards,
Anil.B.R
Acer Extensa... | Answered on Sep 27, 2010
Please check the RAM
Acer Extensa... | Answered on Aug 03, 2010
You should be able to remove the password from the CMOS setting.
Just select F1 at boot up and locate the password section once you are in the CMOS Setting then clear it .
Regards
Acer Extensa... | Answered on Feb 25, 2010
Acer Extensa 4620-4648 Notebook Logo
Popular Tags
34 questions posted
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
View Most Popular
Extensa Acer
  • Extensa Acer
Most Popular Question
acer 4620z boot
  • Computers & Internet
