20 Most Recent
A D S Creative ZEN Stone MP3 Player Questions & Answers
I got a CD-RW and i wanted to transfer the music
Try transferring directly from the disc and don't use the 'automatic' transfer that a computer sets up for you. the computer has to follow all the rules and regulations, but if it's for personal use, go to the My computer and select the CD drive, open files and copy/paste to where you want them.
My i pod not store video
carefully read the user manual to know the video format it supports but for most ipods, I can recommend mp4 formats for video but you have to synchronize from itunes. And also make sure you are using an updated itunes.
Need manual for zen creative 2gb mp3 player
You can find the manual here:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17437&prodName=ZEN+Stone+Plus+with+built-in+speaker
What could be causing my Powered Sub Woofer to
Model specification would help with this, but it could be dirt (or fur if you have pets) in the circuit. This is to assume that the unit is in a standby mode rather than off or unplugged. If the subwoofer is a powered sub, then the problem is more than likely in the sub. Verify this by unplugging the cable from the main unit and see if it still crackles. I would need a Make/model to diagnose any further.
Power doesn't come on, and
Any connections that come loose can be resoldered. It is an easy DIY fix with a soldering iron and some solder. This is what you need:
http://sub.allaboutcircuits.com/images/55007.jpg
To get at the circuitry of the sub remove the rear panel by undoing the screws around the edge. Be sure to have the unit unplugged from the wall and all in and outputs disconnected.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
