20 Most Recent Samsung HL-67A510 67" DLP HDTV Questions & Answers
Samsung HL67A750 has bad main board but is also arcing from all HD inputs.
Do you mean you have power between the grounds of the HDMI ports...if you measure the metal part of the connector to frame ground you get a voltage reading?
3/8/2018 2:42:58 AM • Samsung... • Answered on Mar 08, 2018
0answers
Why won't it turn on?
Be the first to answer 12/24/2015 12:02:39 AM • Samsung... • Posted on Dec 24, 2015Be the first to answer
Where is Fan #1 on a Samsung 67" DLP HDTV
There are 3 fans with this set. Two of them are at top [inner side] and one in the light engine [inside the light engine]. There is no such button to reset the fan only. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
11/3/2014 4:02:57 PM • Samsung... • Answered on Nov 03, 2014
There is a message on
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
7/8/2014 8:36:42 PM • Samsung... • Answered on Jul 08, 2014
SAMSUNG TV
I don't have a schematic for this model. So try this.. .when you open the back of the set, you can readily see two fans, a smaller one on the left, and a slightly larger one on the right. Fan #3 should be behind the larger fan in the front and slightly to the right of it. I would first see if it is operating. You can try to clean it with compressed air ensuring you rotate the fan in its normal direction and don't overdo it. If you can hold the blades so that they are not rotated by the compressed air too fast or at all. You might have to slide the main assembly out to get at it and there should be videos on youtube that show yours or a similar model. Anything further I suggest a trained technician.
7/8/2014 12:14:18 AM • Samsung... • Answered on Jul 08, 2014
0answers
Hl-67a750a1f
Be the first to answer 4/30/2014 3:45:44 AM • Samsung... • Posted on Apr 30, 2014Be the first to answer
Can you replace the screen on Samsung 67a DLP
Elisha,I was not able to find anywhere selling a replacement screen. May I ask why you want one? Did it get damaged? http://www.youtube.com/watch?v=-xUhOdzwLtw Did you have the unit looked at by a repair tech? What is the year of your unit and symptoms? The screen is just like a projector screen (DLP stands for digital light processing) It does not have pixels like a monitor or TV has and doesn't wear out or break unless it was physically damaged. If you could get one the cost of repair would likely exceed the value of the unit. If you have picture issues it typically is the lamp, color wheel, or dmd board or a defective capacitor. Have you registered your unit with Samsung with current contact info? You may be part of the class action suit that Samsung recently settled http://reviews.cnet.com/8301-33199_7-57376508-221/samsung-power-defect-causes-some-tvs-to-fail-and-a-class-action-suit-follows/ you can try the link to http://www.samsung.com/us/capacitorsettlement/ but it is not working for me.
1/17/2014 7:03:21 PM • Samsung... • Answered on Jan 17, 2014
Can you replace the screen on a Samsung DLP 67a
Yes. The hard part is finding one! the screen itself should not be very expensive as with a flat screen for it is only a reflected surface and as long as the glass on the back is intact, the plastic front can be replaced.
1/16/2014 8:59:25 PM • Samsung... • Answered on Jan 16, 2014
2answers
What is the solution to the white dots in the
Replace the optical engine. See my tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine for help with getting a new one and installation.
Thanks for using FixYa and for the great rating.
hardrocko
3/23/2013 4:18:57 AM • Samsung... • Answered on Mar 23, 2013
My 67" samsung tv work well when its on but when you turn off tv and turn back on you get sound and no picture unplug tv and plug in again picture come back on
First thing I would try is to remove set and a box or receiver if used from power for a while and then plug all back up--should reboot all units that way--cannot hurt and may very well help. Not just the set but any unit between signal source and set.It might also be a good idea to see if when the screen is black if the lamp can be seen--is it on or not?
12/12/2012 4:26:32 PM • Samsung... • Answered on Dec 12, 2012
White dots samsung hl-s6187w dlp
Your DMD (Digital Micromirror Device) is failing, It roughly has 900,000 mirrors on the chip that move away or towards the light for shading. You may be able to find this board through Shop Jimmy or by simply googling dmd board for your model#
8/13/2012 10:56:33 PM • Samsung... • Answered on Aug 13, 2012
My tv only shows in green and purple
Have you examined the color wheel this set should have?look for (remove lamp as it faces that) any segments broken or missing.A color wheel also can have a high pitched or fan like sound but not always.check the wheel first. 6_15_2012_8_06_07_pm.jpg
6/15/2012 8:06:13 PM • Samsung... • Answered on Jun 15, 2012
Tv plays but turns off and blinks
If a DLP suspected reasons are:LampLamp BallastColor Wheel etc.
5/4/2012 6:47:36 PM • Samsung... • Answered on May 04, 2012
Replaced the balast, tv not longer turns on and off but now it has a kind of pulsing picture. Am I looking at a new bulb? a new color wheel ? or some other surprise that I haven't heard about?
Lamp is possible especially if the ballast was bad--it powers the lamp.Color wheel will usually display some issues--high pitched whine or fan like noise---with the lamp removed look where it faces--color wheel is there--any broken or missing pieces and it is the problem---The wheel is directly connected to the set---set will detect if wheel not moving or moving too slow etc and almost instantly turn the lamp OFF.4_30_2012_5_06_35_pm.jpg
5/1/2012 3:56:00 AM • Samsung... • Answered on May 01, 2012
Samsung HL-67A510 67" DLP HDTV Logo
60 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
fan 1 samsung 67 dlp hdtv
  • Televison & Video
