20 Most Recent
LG LDS5540ST Semi-Integrated Dishwasher with FlexibEasyRack Plus Sy Questions & Answers
LG ldf8072st after 40 minutes or so into a wash I get a IE code.
Make sure the water valve is fully opened. Check the water supply hose. Make sure that the line is not kinked or sharply bent.
Check the following for the IE error:
- Check the water pressure.
- Check the water tap or valve.
- Check the water supply hose.
- Check the water supply.
LG LD-2052SH. Hi, I have an LG dishwasher and the upper spray arm is not cleaning satisfactorily.
Remove the upper wash arm from the rack. Examine thoroughly. Look for hair line cracks especially if the wash arm is plastic. Top rack wash arms have spray holes on the top AND bottom. Check both places. Sometimes small fish bones will clog the hallway of wash arm not just the holes. After years of use, the wash arm will bow especially plastic ones. Be sure the water connection to wash arm is Secure. If you think the wash arm is not spinning, try this. Place a old cell phone inside a sealed glass jar and start recording video from the lower rack. Be sure jar is Secure. The light from phone will come on. You might see the problem this way.
I have an LG dishwasher that gives me an EO error
The logic Board inside the Control Panel says 'If this machine on _this_ cycle doesn't drain within xy seconds, I will throw an error code'.
Take your high loop and run it into a pail, does it run well, does it throw the code? No? That's your problem, Yes, move onto the next test.
Clean the filter strainer in the machine, and what about the fine filter below the strainer that protects the wash pump? Working now? That was the issue. No? Move to next test.
Remove the Drain Pump and see if you can disassemble it? Look for debris inside and look to see if the impeller is damaged/ Or just replace it AT THIS STAGE, not before the other tests. Diagnose, and then replace..
https://www.google.com/search?q=LG+dishwasher+EO+error
LG Stainless. P/no 3850DD3006A NOT drying dishes or seemingly getting hot water. Any ideas?
Check the heating element. A quick functional test is to start a cycle that uses the heating element, cancel it after a couple of minutes into that cycle, then (carefully) put your hand near it to see if it is warmer than the surrounding parts. If not, start there.
If you are familiar with the use of a multimeter, and you can get at the underside of the dishwasher, you would disconnect power to the dishwasher, find the heater terminals underneath, then measure the resistance. It should be a low value, not more than a hundred ohms or so (this type of heater probably has a resistance around 10-30 ohms). Look for oxidation on the terminals or connectors on the wires. If there is corrosion, (especially signs of water leaking onto the terminals), clean that up and fix any leaks. If the heater reads open, replace it.
How to uninstall upper spray arm for LG dishwasher D1453
To be ale to remove the upper spray arm on the dishwasher pull the upper rack forwards and then turn the nut located above the spray arm and under the rack in a counterclockwise turn and then pull down. The spray arm will become loose to be able to detach and remove . To take out the top spray arm start first by removing the cutlery rack.
LG14AW2 Dishwasher OE code after 3 minutes
Hi Ian,This means the water is not draining out of the dishwasher - probably the filter is clogged. Your dishwasher has a filter fitted in the drain that prevents scraps of food from entering the pipes. Please try to clean the filter, hope this is helpful.If the problem persists please see more possible reasons here:https://www.repairaid.co.uk/dishwasher-repairs/not-draining/ThanksDan
