20 Most Recent
Olivetti wireless All-In-One InkJet Printer Questions & Answers
I cant locate the position
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Wait 10 seconds, and the ink-cartridges should "slide"
to the position from where you can see (and remove/replace) them.
10/16/2010 3:43:33 PM •
Olivetti...
Answered
on Oct 16, 2010
Olivetti ANY WAY printer to windows 7 laptop
The best place to check for a new driver is on Olivetti's website since they are responsible for supporting their products.
Unless the unit is very old, they will probably have a driver for it in their support section.
8/19/2010 3:45:30 PM •
Olivetti...
Answered
on Aug 19, 2010
Install to laptop
First install its software then attached with laptop. It will detect its driver so installed it and then make a reboot. It will work properly.
Good Luck
5/17/2010 7:00:10 PM •
Olivetti...
Answered
on May 17, 2010
Windows 7 driver for Olivetti any_way photo wireless plus
If you download and unzipp the Vista Drivers find them in the Olivetti folder click on drivers, then eng, right click on the driver setup and select properties - then compatibility then select run the program in Windows Vista compatibility mode. It worked for me :)
5/16/2010 7:04:30 PM •
Olivetti...
Answered
on May 16, 2010
Doesn't recognize the color ink cartridge
Good day!Your cartridge is the problem..even if its new or original if the printer never detected or sense your cartridge's presence..then that error will appear..
So,try to change a while or borrow if you have friends there just for reading or proven the problem..
mastergani
4/3/2010 9:44:47 AM •
Olivetti...
Answered
on Apr 03, 2010
Hi
I have an any_way wi-fi
reinstall the printer driver.the current drivers which you have installed have got corrupted so the printer is not working properly.delete the old driver and reinstall the new drivers again and check out this will work.there are many other facing this same problem for wireless printer connection due to drivers not getting installed properly or drivers getting corrupted.
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
3/25/2010 12:36:03 AM •
Olivetti...
Answered
on Mar 25, 2010
