20 Most Recent
Samsung SCX-4828FN All-In-One Laser Printer Questions & Answers
Error #U1-2330 Turn off then on
Dear
Its related to fusser assy. and smps. Mostly the thermostat of the fusser assy. fails. replacing the thermostat can over come the error. some times heating lamp fails very rare. Also Smps could not supply the voltage to the heater lamp.
11/6/2021 5:37:54 PM •
Samsung...
Answered
on Nov 06, 2021
Scx 4828 esta com erro
The best is if you deinstalate your samsung drivers from your computer, if the deinstallation is done you need to reboot your computer so All the program info are deleted, the installate the driver iser from the original samsung CD or from the samsung web site to your computer, you need to download the printer and the scanner driver and the DR. Printer from the samsung download site if you do not have the CD!
8/18/2019 12:12:59 PM •
Samsung...
Answered
on Aug 18, 2019
Where is paper sensor located?
if you are talking BOUT THE EXIT IT IS IN THE UPPER LEFT BEHIND THE FUSER COVER IF YOU ARE LOOKING FROM THE BACK.
7/26/2018 10:25:42 AM •
Samsung...
Answered
on Jul 26, 2018
Our Samsung SCX 4828FN printer
Check the device drivers. You can go to the list and locate the printer setup area. Do an update of the drivers and see f that fixes the problem.
2/19/2018 9:00:02 PM •
Samsung...
Answered
on Feb 19, 2018
System Error: Cycle power is
please disconect the printer for 5 minutes from the e-socet then conect it and try, if it still not work deinstallate the drivers and reboot the computer then installate the driver's from the samsung download site to your download folder first so they are availebl later again then installate the printer driver and the scanner driver and Dr. Printer an reboot the system again now check it should work proper now.
11/13/2017 7:14:59 AM •
Samsung...
Answered
on Nov 13, 2017
Paper feed pickup?
Servicing or replace paper pikup parts: pikup roller , separation pads, solenoid etc
8/13/2015 9:52:28 AM •
Samsung...
Answered
on Aug 13, 2015
After reset chip printer, printer
U have wrogly upgrade d the firmware.of the main board.Try with a fresh copy of original Samsung firmware.
Elase replace main board.
8/13/2015 9:51:46 AM •
Samsung...
Answered
on Aug 13, 2015
