20 Most Recent
Kyocera FS-5025N Laser Printer Questions & Answers
C5025N SERVICE CODE 7001 AFTER
That is a Toner motor K error: Over-current at toner motor K is detected for 80 ms in total while toner motor K is ON.
It may be caused by Defective drive transmission system of the toner motor K.
Check if the gears rotate smoothly. If not,grease the bushings and gears. Check for broken gears and replace if any.
If this does not help, please replace the toner motor K
Im having a serious issue
1. Click Start > Printers and Faxes
2. Right click the Kyocera printer and select properties
3. Select the "Device Settings" tab
4. Click "User"
5. Enter your User Name and Department Code
6. Click OK, OK
If you don't know the User Name and Department Code, these can be programmed by using the "KMNet Viewer" software utility, you can download it from here:
http://www.kyocerasupport.co.uk/index/download_center.false.driver.FSC5025N._.EN.html#
How to remove left and side casing from kyocera
FS-C5025N left cover removal.
1. Open the rear cover.
2. Open the top cover.
3. Remove the opening and closing axis from the main unit frame and then remove the top cover. It pry's out at the hinges.
4. Open the left side cover and then remove the one screw.
5. Remove the waste toner box. To remove waste toner box, press the lock lever in.
6. Remove the paper feed unit .
Trying to add a kyoceran fs c5030n to our network.
You need to make sure the proper IP address is set in the printer for your network. If your network uses DHCP that is the easiest. Go into the menu and check/set your network card to use DHCP. Turn the printer off and back on. Go to kyoceramita.com and download the current driver. Run the driver setup and it should find the printer on the network and walk you thru the setup. let me know if you need more help.
The print size for the paper is defaulting back to
This sounds like you are setting the size in the application rather than the printer system properties.
To set the system printer properties, Click on Start>Control Panel>Printers
Select the Kyocera >Properties
Set the desired paper size, click OK.
The paper size should remain as selected until you decide to change it again.
You will still be able to temporarily change the printer properties for the application job.
Please rate this solution. Thanks.
No installing option
locate the file you downloaded on your computer (hopefully on the desktop so you can find it) double click on the downloaded driver to start the install.
