20 Most Recent Konica Minolta Bizhub C300 All-In-One Printer Questions & Answers
its done automatically and you can do it in the service mode
Konica Minolta... | Answered on Feb 18, 2019
replace the yellow image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 25, 2018
cyan image unit
Konica Minolta... | Answered on May 10, 2016
Mike does this happen with all prints? does it go away if you change the orientation of the paper. portrait to landscape? Happen when you copy ? Try different file type does that change?
Konica Minolta... | Answered on May 05, 2016
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
replace the fuser unit
Konica Minolta... | Answered on May 03, 2016
clean the print head glasses
the cable will not connect to the copier????? do have the print drivers for this model machine
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Konica Minolta... | Answered on Jan 19, 2016
For P-7 replace the magenta image unit
for P-5 and P-28 unless you know your way around Konica Minolta Copiers you need to have the two sensor located below the transfer belt on the right side cleaned and or replaced, to clean them you must uncover them because when the belt assy. is remove the are covered.
Konica Minolta... | Answered on Jan 10, 2016
i dont know it your network????
then replace the image units for those colors
have the printer control board firmware re-flashed by Tech because firmware is only available via secure Konica Minolta web site they keep their firmware secure,
Konica Minolta... | Answered on Dec 30, 2015
and check if the machine starts correctly.
Konica Minolta... | Answered on Dec 29, 2015
Exposure lamp failure to turn on, raise the doc feeder hit the start button bright light come on under the big glass if not replace the exposure lamp and board if required.
reset procedure if code comes back get the lamp
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day.
Setting Software DIP SW1. Setting method
This setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in
the non-volatile memory every time it is
changed.
Caution 2: The numbers shown in the message
area are defined as follows:
Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF.
Example: 04-7 : 1 A8
Bit data
1 : ON
0 : OFF
Bit number (0 to 7)
Switch number
2. Setting proceduresStep1
Operation procedure
Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on.
Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key.
Select bit number of the DIP switch.Use the center [  ] , [ ] key.
Select ON (=1) or OFF (=0) of the DIP switch.
Use [ON] or [OFF] key.
[ON] : Set bit.
[OFF] : Clear bit.
Press the [Return] key to return to the 25 mode
menu screen.For each switch function, refer to "List of Software DIP switches".
25
Konica Minolta... | Answered on Dec 28, 2015
1st check the easy possible cause, stain /dirt on slit/original glass CLEAN. 2nd check drum for scratch causing line on copy and the transfer belt for damage.
Konica Minolta... | Answered on Nov 19, 2015
Replace the image unit for the offening color.
Konica Minolta... | Answered on Nov 14, 2015
replace the cyan and yellow image units
Konica Minolta Bizhub C300 All-In-One Printer Logo
78 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
codes f 34 f 35
  • Office Equipment & Supplies
