20 Most Recent
Weed Eater Weedeater 26" Riding Mower Questions & Answers
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
What are the advantages of using HDPE pond liner sheets for constructing a pond?
Here are the advantages of using HDPE pond liner sheets for constructing a pond:
- Durability and Puncture Resistance: HDPE is a tough material that can withstand wear and tear. It's resistant to punctures from rocks, roots, or other sharp objects that might be present in the soil under your pond. This translates to a long lifespan for your pond liner, minimizing the need for replacements.
- UV Resistance: Unlike some materials that degrade under sunlight, HDPE liners are UV resistant. This means they won't become brittle or break down over time when exposed to the sun, ensuring the liner lasts for many years.
- Chemical Compatibility: HDPE is non-toxic and resistant to many chemicals. This makes it safe for fish and plants in your pond, and it won't leach harmful chemicals into the water if you need to treat the pond with certain substances.
- Suitable for Large Ponds: HDPE liners come in large sheet sizes, making them ideal for constructing bigger ponds. The large sheet size reduces the need for seams, which can be weak points in a liner, and simplifies the installation process for larger ponds.
- Relatively Easy Installation: While professional installation is always recommended, HDPE liners are lighter than some other pond liner options and can be workable for DIY projects. They can be welded together to create a secure seam, and their flexibility allows them to conform to the contours of your pond.
- Cost-Effective in the Long Run: Although the upfront cost of HDPE liners might be higher than some other options, their durability and low maintenance requirements make them a cost-effective choice in the long run. You won't need to replace them as often, and they can help prevent leaks that could damage your landscaping or require repairs.
3/18/2024 7:08:38 PM •
Garden
Answered
on Mar 18, 2024
Where can I find a baumr-ag sx45 0.325 chainsaw cog
usually doing a bit of research on google con bring you up a parts list & suppliers. with the make and model number & then type in either service manual or parts list.pdf. of even a schematic can bring you pictures or websites to help. maybe some scrolling through is needed but you should be in the ball park with this one.
3/15/2024 11:12:06 AM •
Garden
Answered
on Mar 15, 2024
I would like to print out a service and parts manual for a 2015 ck30
Obtaining a service and parts manual for a specific model, such as the 2015 CK30, typically involves contacting the manufacturer or an authorized dealer. In this case, CK30 likely refers to a compact tractor model, and the manufacturer would be KIOTI.
3/9/2024 2:05:09 PM •
Garden
Answered
on Mar 09, 2024
Are the cushions on my outdoor sofa waterproof?
Cushion covers are treated with a water repellant coating. Spilledliquids can be easily wiped off. I would recommend removing andstoring the cushions in a dry place when not in use
3/6/2024 9:46:54 AM •
Garden
Answered
on Mar 06, 2024
