20 Most Recent
Kyocera Copystar Printing Systems - 1503LG0KL0 All-In-One Laser Printer Questions & Answers
Kyocera will not print without kprint port
The KM-1650 will print useing a standard TCP/IP port printing over the network, I have done it ever since the machine came out. Load the print driver as a local printer and then setup a TCP/IP port and set the printer to print to that port in the printer properties.
Let me know if yo need more help.
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
