20 Most Recent
Kawasaki Engines NEW 17 HP KAWASAKI ENGINE FH541V-DS22-S REPLACE KOHLER BRIGGS ZERO TUR Questions & Answers
Weed trimmer (2 wheeled) screeches.
All questions need full 'make model (what is is)' as first 3 words please. Very often, issues like this are a known fault and users tell the fix.
You need to track down where the screech is coming from?
Wheels
Drive Belt
Bearings
Piston rings
Or it may be battery operated?
4/24/2024 10:27:50 PM •
Garden
Answered
14 hours ago
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow:
Check the Seals and O-Rings:
Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve.
Unscrew the pump: Remove the pump to access the internal components.
Inspect the seals and O-rings:
Look for any damaged or worn-out rubber seals.
Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place.
Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease.
Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube.
Reassemble the pump: Put the plunger back into the tube and lock it with the handle.
Test the sprayer: Pump it up and check if it maintains pressure without leaking.
Inspect the Handle and Hose:
Handle connection: Ensure the handle is securely attached to the cylinder.
Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose.
Check the Nozzle and Wand:
Nozzle adjustment: Adjust the nozzle to the desired spray pattern.
Wand inspection: Examine the spray wand for clogs or obstructions.
Lubricate O-Rings and Seals:
Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation.
Test the Sprayer:
Fill the cylinder to the desired level (avoid exceeding the maximum fill mark).
Screw down the pump firmly to create an airtight seal.
Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM •
Garden
Answered
Yesterday
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
on Apr 20, 2024
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
Scotts lawn mower 21995x8b manual
I'm guessing you have fixed this or given up after 13.5 years, but here is my suggestion for the next person who has this trouble. If you ran it out of fuel and left it over the winter, it could have a drop of fuel that hardened and plugged one of the fuel ports in the carburetor. I have had this happen and needed to remove the fuel bowl and poke the dried film with a pin. Put it back together and it started right up.
3/31/2024 1:19:11 AM •
Garden
Answered
on Mar 31, 2024
Where can i find choke cable for 422707 model # riding mower.
Do not know what brand that is, but you can find choke cables at lowes, amazon .com. or any number of small engine repair shops depending on where you live. An after market cable could be easier to find and work just as well.
3/30/2024 4:44:30 AM •
Garden
Answered
on Mar 30, 2024
