20 Most Recent
HP LaserJet M1005 All-In-One Printer Questions & Answers
Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Scanner error 20
your scanunit's lamps frecuenci is changed you should replace the scanunit
Hp laserjet m1005 initializing problem
The wizard did not
successfully complete copying your picture because an error occurred.
See details error
information. The
following problem occurred while copying picture: Unspecified error
The following problem occurred while copying picture: Unspecified
error
Scanner error 12 on hp
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Showing display on scanner error 13
This error is triggered if the scanner is not able to determine the end stop for the scanner. Likely an electronic failure but sometimes caused by too much friction in the scanner mechanism and the motor errors out trying to move the scanner.
How can i fix scanner error 20?
That is most likely damage to the scanner itself, you can power it on with the lid up and watch the scanner move back and forth, if it hangs or jitters it is pretty much not worth it to repair unless you are good with taking things apart and re assembling. Sometimes cleaning can help but the labor alone is going to cost you the same as buying a new printer.
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Scanning
Requires use of brain and hands
Full page black
1. one of the contact not engaging to the cartridge.
2. chk with another cartrdige
3. Replace DC control board
