20 Most Recent
HP Deskjet 1120c InkJet Printer Questions & Answers
Have a paper jam and dirty roller on my HP 1120c inkjet printer
This might help. Videos from youtube.
https://video.search.yahoo.com/search/video;_ylt=A0SO8xbH5nxaQIAA8Q1XNyoA;_ylu=X3oDMTExbGtvMmJiBGNvbG8DZ3ExBHBvcwMxBHZ0aWQDVUlDMV8xBHNlYwNzYw--?p=Have+a+paper+jam+and+dirty+roller+on+my+HP+1120c+inkjet+printer&fr=yfp-t
My HP Deskjet 1120Cxi fails
Power on the machine, check front panel 'cartridge led' blinking? replace the cartridges,if 'paper led blinking' indicates paper jam check for paper jam.If printer comes in ready mode check in system drivers its is ready mode?.. if no check parallel cable if its good replace formatter..
Hello, My HP deskjet 1120c
in control panel go to printer and faxes. there you will get your printer in printer tab. right click on your printer model, go to property, to printing preference. there in maintenance tab go to head cleaning. run the head cleaning programme once or twice. your problem will solved.
thank you
HP1120C PRINTER.
My print image starts
Welcome to Fixya
Try to reset the printer. Resetting the printer is useful for quickly clearing minor software problems so you can continue working. You should allow approximately five minutes to reset the HP 1120c.
1 Turn off the HP 1120c by pressing the power button.
2 Disconnect the power cord from the back of the printer and unplug it from the wall.
3 Wait for 30 to 60 seconds.
4 Reconnect the power cord to the back of the printer and to the wall.
5 Press the power button to restart the HP 1120c
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Print only red and black
First, use the HP Printing Assistant software to check the ink-level in the tri-colour ink-cartridge.
If empty, refill or replace the ink-cartridge.
Then, use the same software to run a few "print-head-cleaning" cycles,
just in case that some of the "colour" ink-jets are clogged.
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
My HP 1120cxi was workinh fine until i reinstalled
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and
go directly to downloading the tool
Connectivity
USB: Ensures that the USB connection from your computer to the HP product is working correctly.
Network:
Ensures that the network connection between your computer and your
network is working correctly. If the tool detects a network connectivity
problem, you will be prompted to run the HP Network Diagnostic Utility
for better results.
Spooler
: Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
Online status
: Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
Device manager
: Checks for problems in Device Manager that would prevent printing.
Print queue
: Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
Port
: Checks the port settings for the HP product.
Driver
: Checks for alternate-driver settings.
Conflicts
: Checks for conflicts with other drivers, such as other printer brands.
Default printer
: Checks the default printer setting and prompts to select the HP product as default (optional).
Keep printing **** not in english
got to advanced setup...change the language..else...what u need to do just disconnect the usb cable..put the cd in...go to computers>>right click on the cd icon>>explore>>utill>>ccc>>uninstall l2...then restart the computer..dnt connect the usb..reinstall the printer...whenever it will ask u to put in the usb cable do that...best of luck..
HP deskjet 1120c printer does not print -light blinks
ok try to add a printer in your computer select local port and it should be USB and the USB cable should be plugged in the computer and select the brand to be HP and the model to be 990c click on next till the FINISH appears and after that the printer will print from the computer
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color.
If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
