20 Most Recent HP DeskJet D1460 InkJet Printer Questions & Answers
the obvious fault is a lack of communication between the computer and the printer from not having the correct driver installed
using microsoft drivers can lead to problems so it is best if you go on the HP web site , select the driver download for you model and install the driver direct
you can also right clivk on the printer and then click on properties tab , click on compatibility tab then click in the box and high light the win os you are using to rectify compatibility problems
HP DeskJet D1460... | Answered on Oct 21, 2017
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
HP DeskJet D1460... | Answered on Feb 08, 2013
Hi
The power light is blinking because one of your cartridges are bad. Hence need replacement. Try with the black cartridge as normally this goes bad.
HP DeskJet D1460... | Answered on Mar 16, 2012
Click on the URL below, this will take you to the HP support site for your printer. Select the operating system you are using, then under Driver-Product Installation Software, sellect the HP Full Software and Driver. This will be a large file, but contains everything that was on your CD.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=501857&lc=en&cc=us&dlc=en&lang=en&cc=us
HP DeskJet D1460... | Answered on Feb 08, 2012
Turn off the printer.
Disconnect the printer and unplug it from power.Do the same with the PC.
Reconnect them after a while.
Turn the printer on and start the PC.
Make sure the usb connections are well fixed.
Now print.
Hope this helps.Thanks!
HP DeskJet D1460... | Answered on Oct 10, 2011
Hello and Welcome to FixYa!
Sir/ Ma'am The Power Light (Green) is blinking means a lot of things, like the printer is out of paper or the top cover is open and other, If you get a message as "Paper Jam with the green light flashes continuously it means there is a paper jam, So Unplug your printer and Remove any loose sheets of paper from the input tray and the output tray. But if you are not getting any message and if the green light flashes then it means that either the cover on the HP printer is open, or the printer is out of paper.
If the cover is open, close it or If the product is out of paper, Follow these steps to load paper
Move the paper width guide to its outermost position then Insert the paper into the tray, and then gently push the paper into the product until it stops.Move the paper width guide inward to rest against the paper.
Now Turn On your printer and try to print again if you are getting same thing then there is may be some other issue like The Power light (green) blinks when trying to print labels. The product is not picking up labels or paper correctly (The type of labels or paper might be inconsistent with the product settings)
Follow these solutions to resolve the issue of the product not feeding labels or paper correctly. Open the document you were trying to print, if it is not already open,
Click File >> click Print , and then >> click Properties . The Printing Preferences dialog box opens >> Click the Paper/Quality tab.
Make sure that the type of paper listed in the Type is drop-down list matches the type of paper loaded in the product, Now Try printing again.
I hope problem will be solve by one of above solutions
But if you still face this similar problem then there must be an issue of cartridge. Let me know if you still face the problem i will provide you the assistance about the cartridge problems that may cause the green light flashes and do not allow to print.
Thank You
HP DeskJet D1460... | Answered on Sep 25, 2011
Hi......................
How to Clear a Paper Jam on an HP Inkjet Printer?????
Paper jams are among the most common problem with HP inkjet printers. Follow these instructions to learn how to clear a paper jam so you can get back to work.
Instructions Things You'll Need
  • HP inkjet printer
    • 1 Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
    • 2 Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
    • 3 Look for paper through the opened back panel. Remove any paper you find jammed.
    • 4 Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
    • 5 Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
    • 6 Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
    • 7 Close the front access panel. Make sure that it latches back into place.
    • 8 Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this will helpful to you...................
Good Luck.............
HP DeskJet D1460... | Answered on Sep 24, 2011
In most cases the printer driver software can have errors while being in use or is shut down. First remove the ink cartridges, the B&W . Now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
HP DeskJet D1460... | Answered on Sep 17, 2011
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
HP DeskJet D1460... | Answered on Aug 09, 2011
Make sure the printer is on..try unistalling the drivers and then reinstalling the drivers
HP DeskJet D1460... | Answered on Aug 07, 2011
Yes if you install the correct Windows version printer driver.
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
HP DeskJet D1460... | Answered on Jul 25, 2011
HP DeskJet D1460 InkJet Printer Logo
104 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
hp d1460 wont print test page wont print
  • Office Equipment & Supplies
