20 Most Recent
Konica Minolta magicolor 8650DN All-In-One Laser Printer Questions & Answers
I HAVE JUST BOUGHT A
C1183 is for Finishing Option Elevator Drive Failure. Most of the time when I see this code it is because 1 or both bins are not fully inserted into their slots. The bins when all the way in will trip small switches to tell the machine where the bins are. In your case this may not be true due to the noise you are hearing unless the elevator has already driven the unit all the way to the top or bottom.
C11BO is for Finishing Option Stapler Unit CD Drive failure. I have never seen this code come up before but as you can see, both of these codes are coming from the Finishing Option which you have just installed. It is very possible that the unit has some shipping or other damage and there is nothing you have done wrong. If it were just the C1183 I would feel differently.
I would start by checking the stapling unit and make sure that you got the packing tape and materials out of the inside of the finisher that hold the stapling unit during shipping. Most likely the 1183 code was from the bins but I am not sure of that as it could also be a shipping damage issue. Hope this helps!
Good Luck and Thank You for using Fixya.
WheatlandServices
How can i fix the problem for error code c-3423
If after this procedure the code comes back replace the fuser unit continue reset the fuser will catch on fire that will ruin a perfectly good day
1. Turn OFF the power switch.
2. Turn power switch ON while pressing the Menu/Select key.
3. Check that the Trouble Reset screen appears.
4. Press the Menu/Select key.
5. Check to make sure that [Completed. Please turn power OFF and ON.] is displayed
and the it has been reset.
6. After turning off the power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
