20 Most Recent HP Pavilion 7965 PC Desktop Questions & Answers
The computer doesn't start. It
an old desktop the PSU is shutting down (try do that as feature ! ' overloaded) there are only 2 causes. 1: bad PSU. 2: the mobo or anything plugged into it are shorted. want to do tests to find it , ? takes going inside, if shy , get it fix. or tell helper you have a screwdriver and are brave. no danger to you but to it , yes. (stay out of PSU ok?)
2/25/2018 4:12:18 PM • HP Pavilion 7965... • Answered on Feb 25, 2018
How 2 enter hp povlion cos
what is your question?
10/26/2016 5:10:03 PM • HP Pavilion 7965... • Answered on Oct 26, 2016
2answers
My hp 7965 pc desktop
Some Software Applications May Cause Windows Stop Responding or Restart During Startup or Boot in Windows XP.
If a PC that has been working properly fails to startup or boot, especially after a new application or driver is installed, it is necessary to perform one or more of the following methods to correct the problem. The PC may lockup, freeze, hang, or automatically restart when the Windows Desktop first displays during startup.
Method 1: Disabling automatic restart
This method disables automatic restart if you are unable to view Windows Desktop and/or the notebook continues rebooting automatically (whether by the user or the notebook continues booting without user intervention).
1. During the rebooting process, repeatedly press the F8 key to enter Windows Advance Options Menu.
2. Use the up and down arrow keys to select Disable automatic restart on system failure and then press the Enter key.
3. Use up and down arrow keys to select the operating system to start (if more than one OS is installed).
4. Press the Enter key. Windows should start.
Method 2: Use last known good configuration
Using the last known good configuration may allow the pc to boot to Windows using the most recent settings that worked.
2. Use the up and down arrow keys to select Last Known Good Configuration (your most recent settings that worked) and then press the Enter key.
4.Press the Enter key.
Method 3: Use System Restore to reset Windows to an earlier known safe operating point
This method reverses recent operating system changes to the notebook PC, such as the installation of new software, and takes the computer back to a previous working state. This method may uninstall or remove the software that is causing the problem. Check with the software manufacturer for any known problems and reinstall the software if appropriate.
1. Start Windows in the Safe Mode as follows:
- Remove any disks or CDs, and disconnect any external devices or peripherals.
- Press and hold the Power button for 5 seconds to turn off the computer.
- Press the Power button to turn on the computer.
- Press the F8 key repeatedly when the first screen appears.
- From the Windows Advanced Start-up menu, select Safe Mode and press ENTER .
The computer may run slower in the Safe Mode and the desktop will not look as nice due to reduced colors.
2. Click Start , then click Help and Support .
3. On the Help and Support home page, click System Restore .
4. On the System Restore page, select the Restore my computer to an earlier time option and click Next .
5. Navigate through the calendar looking for a highlighted date and select a restore point date and time that is earlier than when you started experiencing the problem, then click Next .
The computer should shut down and turn back on by itself after the restoration completes. When the Restoration Complete window appears, click OK to continue.
Method 4: Uninstall recently installed applications using Add/Remove Programs
- Press and hold the Power button for 15 seconds to turn off the computer.
- From the Windows Start-up menu, select Safe Mode and press ENTER .
The computer may run slower in Safe Mode and the desktop will not look as nice due to reduced colors.
2. On the Windows taskbar click Start , click Control Panel and then click Add or Remove Programs .
3. Navigate through the alphabetical list of all installed programs and select the name of the most recently installed program or programs.
4. Click Remove , click OK when prompted to verify the removal of the program.
5. Restart the computer by selecting Start , Shutdown , and Restart .
- If the computer starts up properly, contact the software manufacturer for updated instructions for a proper installation.
- If the computer does not start up properly, reboot the computer in the Safe Mode and repeat the methods for uninstalling any other recently installed software.
Method 5: Remove applications that load during startup using the System Configuration Utility
If the system fails to start properly after installing a new software application, there may be conflicts with the application if it loads during startup. To resolve the problem, it may be necessary to use the System Configuration Utility to remove the application from Windows startup, or to change the startup sequence.
- From the Windows Start-up menu, select Safe Mode and click ENTER .
2. Click Start , click Run , type MSCONFIG , then click OK .
3. On the System Configuration Utility window, on the General tab, select Selective Startup option, and unselect the Load Startup Items .
4. Click OK and then click Restart .
The computer should restart and operate properly even without loading any of the startup items. Most startup items are helpful utilities that run in the background or sit in the system tray until they are needed.
- If the computer does not restart and operate properly, there is a more severe problem and performing the method for reinstalling the Windows OS may be necessary.
- If the computer restarts properly, examine and enable the entries under the startup tab.
7/8/2011 9:03:24 AM • HP Pavilion 7965... • Answered on Jul 08, 2011
I purchased a QVS brand
it should not require an adapter the bigger usb portion goes into the printer and the smaller will fit into your usb on your computer back ports. if the ports are to big you bought a mini usb adapter on accident. let me know if this helps.
3/14/2011 11:32:52 PM • HP Pavilion 7965... • Answered on Mar 14, 2011
Hello, I purchased a QVS
Hi, How do u do?? there must be two USB port on the front of the chassis. you can use them, you can also use a USB hub if you need more USB port.
I hope you can find it.
best wishes. Babak *******
3/13/2011 9:00:17 PM • HP Pavilion 7965... • Answered on Mar 13, 2011
Hello. Re: HP Pavillion 7965 Where is
Hi.
The on off switch is located in the front side, right below the drives.
Most HP PCs do not have PSU power switch at the back.
Regards.
Ginko.
11/3/2010 12:03:23 PM • HP Pavilion 7965... • Answered on Nov 03, 2010
I'm trying to re-install windows on my system, but
Just want to clear things. Do you mean entering the BIOS setup is asking for the password?
If that's what you mean, then there's no other way of knowing what's the BIOS password is. However, you can reset the BIOS by opening your computer tower and look for the CMOS battery, take it out for a few seconds then put it back in, it should restore the BIOS to default and password should be no longer an option to enter the BIOS.
9/12/2010 6:25:58 AM • HP Pavilion 7965... • Answered on Sep 12, 2010
Attempting a system restore with HP recovery disks
How many Optical drives do you have installed?
Try only using one Optical drive and one hard drive both on separate IDE channels
4/15/2010 12:57:48 PM • HP Pavilion 7965... • Answered on Apr 15, 2010
2answers
HP Pavilion 7965 not booting
You have to have ram memory in, for the computer to operate at a basic function. To get to the BIOS POST screen.
NOTE*
When changing out hardware do you have the power disconnected from the computer?
Yes, I know, but I have to ask.
Also, do you follow anti-static precautions before sticking your hands inside the computer?
Touch the metal frame of the open computer case before reaching inside?
Your body carries Static electricity.
Static can fry out the hardware components inside your computer.
Especially the Processor, which is the most susceptible hardware component to static shock.
1) Computer unplugged from power. Video card removed. Monitor plugged into VGA port on the motherboard. Ram Memory installed. Harddrive data (Interface) cable disconnected, and power cable. Same for any optical drive/s.
Press the Power On button in, and hold it in for a count of Five seconds.
Let go.
Do this procedure 2 more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup back to the factory default settings.
Plug back into power. Wait 1 minute. Turn the computer on.
Do you get the BIOS POST screen? Let's start from here.
3/1/2010 4:32:56 PM • HP Pavilion 7965... • Answered on Mar 01, 2010
2answers
How to enter system recovery partition hp pavilion
At start up go to the BIOS by selecting the proper F key. When in the BIOS mode look for instructions at the top or bottom of the screen to hit F keys like F10 for System Recovery.
10/29/2009 5:03:05 AM • HP Pavilion 7965... • Answered on Oct 29, 2009
Reboot my pc
Excellent article to troublshoot startup available by clicking here.
Otherwise be alittle more specific, let us know your os, etc, and we'll be happy to help sort it out...
5/15/2009 10:20:26 PM • HP Pavilion 7965... • Answered on May 15, 2009
Start system recovery
Put disk 1 and restart Windows. When it restarts, it'll start recovery. At some point it'll ask you to switch to Disk 2.
3/20/2009 10:25:21 PM • HP Pavilion 7965... • Answered on Mar 20, 2009
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
2/17/2009 4:17:25 PM • HP Pavilion 7965... • Answered on Feb 17, 2009
HP PAVILION 7965
It might be due to overheating problem. so clean the processor fan thoroughly.
1/11/2009 11:56:01 AM • HP Pavilion 7965... • Answered on Jan 11, 2009
I have email error 99999
delete and reinstall your email software.
6/25/2023 8:52:09 PM • HP Pavilion... • Answered on Jun 25, 2023
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
11/30/2022 7:10:30 AM • HP Pavilion... • Answered on Nov 30, 2022
How do i get mywindows keyboard to work
desktop or laptop. ? external Keyboard or internal
6/9/2022 10:54:32 AM • HP Pavilion... • Answered on Jun 09, 2022
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
6/2/2022 6:19:00 PM • HP Pavilion... • Answered on Jun 02, 2022
Hp pavilion entertainment pc 17 sd ms pro mmc xd
HP.COM << go there. And ask a real question ,you did not.
5/25/2022 11:36:13 AM • HP Pavilion... • Answered on May 25, 2022
HP Pavilion 7965  PC Desktop Logo
20 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
re hp pavillion 7965
  • Computers & Internet
