20 Most Recent eMachines T6211 PC Desktop Questions & Answers
Which pins on the motherboard do you connect the LED display lights on an emachines T6211?
Hello here is your pc`s homepage:http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1637It depends on the mainboard layout, but it probably look like this:1_3_2013_2_03_32_am.jpgThese to are the most used ones.The manual does not show any detailed description about the mainboard connections.Good luck1_3_2013_2_10_25_am.jpg
1/3/2013 2:11:22 AM • eMachines T6211 ... • Answered on Jan 03, 2013
When I turn on the compute there is a loud beep and nothing opens up
Your computer's RAM memory modules are not being detected. They will need to be removed and their gold fingered connectors cleaned with tissue paper.Now reinstall them and power on the system.Take care!damnor01
9/13/2012 10:17:52 AM • eMachines T6211 ... • Answered on Sep 13, 2012
After about 30 minutes the computer freezes. I
If all of this just started happening after installing the new monitor, then it's probably the drivers that were installed for your monitor conflicting with your computer. Try deleting the monitor's drivers by right-clicking 'My Computer' and selecting 'Properties'. Then, select the Hardware tab and go into Device Manager. Find the Monitors section in the list of devices and click the plus sign beside it to expand the node. Right-click the monitor there and click 'Uninstall' to remove it. Use another monitor and see if the problem still persists. If not, then you know there's a problem with the new drivers for your monitor. You'll need to contact the manufacturer to get updated drivers for it.
10/11/2011 2:22:02 PM • eMachines T6211 ... • Answered on Oct 11, 2011
7/1/11 eMachine T6211 won't boot at all; no
Most probably is a RAM memory issue, those beeps are issued when a RAM module can not be found, may be the machine sufferend a crash an the ram jumped out of it's slot (less probable) or just broke (Most probably) certainly a tecnician can save your data to another PC or even, fix the broken PC by replacing the broken RAM module with a new one
7/3/2011 2:51:02 PM • eMachines T6211 ... • Answered on Jul 03, 2011
Where is the video card
The Video card is intergrated on the board if it has failed you will have to install a new video card there should be some open slots on the motherboard. Tiger direct is a good place to buy but you pick one up a best buy or office depot.
1/9/2011 10:46:22 PM • eMachines T6211 ... • Answered on Jan 09, 2011
I run windows xp and often the voice goes out and
If the sound comes back after Restart even you don't do anything, then there must be some problem with your computer, not only with the Sound driver. It's possible that the sound driver ceases after it runs for a while and it resumes only after the system is restarted. I would highly recommend you to reinstall the sound driver. You can download the sound driver here (Click Here).
I would also suggest you to scan your computer with few antivirus programs. You can use Avg Free, Avira Free and Avast Free. Run full system scans with these antiviruses, but don't forget to install only one of them at a time otherwise it might cause another problem. I hope you have at least one security software (antivirus or antispyware etc..) installed on your computer. Uninstall the currently installed antivirus program and try with the other versions.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
12/10/2010 1:17:22 PM • eMachines T6211 ... • Answered on Dec 10, 2010
Can an emachines T6212 be upgraded with an Athlon
it cannot be done if you want to use the same motherboard
3/27/2010 7:30:53 AM • eMachines T6211 ... • Answered on Mar 27, 2010
Getting no image on emachines t6212
it's pretty simple. everything has its own plug. and the one for the monitor would most likely be a serial connection, it should have pins at the cord and holes at the computer. the mouse and keyboard have their own connections unless they're USB which wont matter which usb connection ur in. the internet if it's high speed it would look like a large phone cable. and has its own plug. everything else should be alright
2/20/2010 10:00:52 AM • eMachines T6211 ... • Answered on Feb 20, 2010
2answers
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
5/25/2009 6:00:04 PM • eMachines T6211 ... • Answered on May 25, 2009
Emachine driver for windows vista upgrade
if you have the disc that come with your computer get the drivers from there.
11/18/2016 6:21:03 AM • eMachines T... • Answered on Nov 18, 2016
3answers
Screen says reboot and select proper bootdevice
Guessing, but it sounds like your hard drive has been damaged. You may need a new drive, or at least repairs. If you have a "rescue disk", give that a try.
9/5/2015 1:25:07 PM • eMachines T... • Answered on Sep 05, 2015
Emachine does not boot both fans are working
Here's a video on how I fixed my emachines boot problem. Almost anything can get in the way of your computer booting. Software, hard drive, RAM, motherboard, processor, etc. Below the video, I attached a link to a tip I made about computer crashes. Computer Crashes and Electrolytic Capacitors
7/1/2015 1:18:06 AM • eMachines T... • Answered on Jul 01, 2015
How to operat speaker
Please specify how exactly you're trying to make them work, what machine you're trying to make them work with, and what kind of connection your speakers are using. General info: Speakers usually get connected via 3,5 mm plug into the green round socket in the back or front of your computer. In Windows, if your speakers are properly connected and set up, right click on the sound pictogram in your taskbar and choose "Playback devices". Set your speakers to be the default playback device by left-clicking on the preferred device of your choise and clicking the button "Set default" below.
8/4/2014 12:53:28 AM • eMachines T... • Answered on Aug 04, 2014
Recovery disk for Emachine T5642
In general, you have to order recovery disks from the manufacturer of the machine. In your case eMachines Store eRecovery is where you can order it, or you can initiate a discussion with tech support. Also, many machines give you the option to burn your own recovery media when you first set it up. Most people skip this step. You should do this before you have problems. Search your machine for the word Recovery and see if you have an installer routine there. Here are instructions to create a recovery disk on a USB stick Create USB recovery drive Windows Help
7/30/2014 10:16:40 PM • eMachines T... • Answered on Jul 30, 2014
Computer does not boot up
Check your monitor cable connections. If not solved, try a different monitor.
5/8/2014 6:41:10 PM • eMachines T... • Answered on May 08, 2014
T5026 bios download
Flashing the bios is a last-ditch move. What happened before that? Did it work before you flashed it? If the unit is interrupted during clash, or if it is the wrong bios, your goose could be cooked. Read this: http://www.techpowerup.com/forums/threads/flashed-wrong-bios.180492/ There may be something you can use, especially if you have a floppy drive (a real one, not a usb-one). You maybe can use flash drive in the usb port, but that's a long shot. Good luck with that. I'd be looking at a new motherboard. They can be had pretty cheaply.
12/17/2013 2:24:36 AM • eMachines T... • Answered on Dec 17, 2013
Problem getting recovery disk
I understand that you want to reinstall the Operating System on the computer. Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer. To start the system recovery:
  1. Restart the computer
  2. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. When prompted with a boot screen, hit the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the operating system.
If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from Recovery Media.
  1. Insert the disk labeled System CD into the computer's disk drive and restart the computer.
  2. When the eMachines logo appears on the screen, press the F12 key repeatedly.
  3. Select either CDROM or DVD as the boot device, this may vary depending on the system.
  4. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
  5. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  6. After the system recovery program has loaded follow the prompts to reinstall the operating system.
Refer the URL for more information and for the link to order the Recovery media if required.
11/19/2013 3:31:52 AM • eMachines T... • Answered on Nov 19, 2013
How do i update my graphics card?
According to the port you have(pcle x16 or pcle x16 2.0), buy a new graphic card , open up the cpu cover and replace it with the old one.
11/28/2012 4:24:36 PM • eMachines T... • Answered on Nov 28, 2012
T3304
I believe it is this,1) http://www.youtube.com/watch?v=KN6_-8fYHo0(Starts at 0:04)2) http://www.capacitorlab.com/visible-failures/index.htm3) http://www.youtube.com/watch?v=YCSNWi3UHf4For additional questions please post in a Comment.Regards,joecoolvette
10/17/2012 5:24:19 PM • eMachines T... • Answered on Oct 17, 2012
eMachines T6211  PC Desktop Logo
Popular Tags
9 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T eMachines
  • T eMachines
Most Popular Question
run windows xp often voice goes out
  • Computers & Internet
