20 Most Recent eMachines T3508 PC Desktop Questions & Answers
How do i EXIT the BIOS sreen ?
The Esc key should exit.
4/28/2014 5:26:40 PM • eMachines T3508... • Answered on Apr 28, 2014
2answers
What type of cmos batterty does an emachine t3508 take?
6/V15H 7.2V 15mAh Ni-Mh Check eBay for best prices
3/3/2013 3:03:17 AM • eMachines T3508... • Answered on Mar 03, 2013
2answers
My laptop is running slow should i use recovery
if u dont have nothing important, then just re-format it and reload Windows
recovery disk will not load OS..u will need win OS install CD
12/27/2012 9:38:17 PM • eMachines T3508... • Answered on Dec 27, 2012
2answers
Power Switch
use external monitor to setup internal monitor setings
11/19/2012 3:06:15 AM • eMachines T3508... • Answered on Nov 19, 2012
2answers
Reset password on emachine 355
If you have forgotten your password if you have another user account with administrative privileges you can log into that account and change your original user accounts password from the User Accounts applet in Control Panel.
If you dont have another account like this set up or dont have the password to it you will need to log into the built-in Administrator account.
In XP Home boot the computer into Safe Mode.
Do this by repeatedly tapping the F8 key as the computer is starting up.
This will get you to the right menu
Navigate using your Up arrow key the mouse will not work here
Once in Safe Mode you will see the normally hidden Administrator account
The default password is a blankIn XP Pro you do not need to go into Safe Mode
At the Welcome Screen do Ctrl-Alt-Del twice to get the classic Windows logon box.
Type in "Administrator" and whatever password you assigned when you set up Windows.If you reset the built-in Administrator accounts password in Home or have Pro and dont remember the password there are ways to change the password for that account to a blank
hope this helps
6/26/2012 3:01:22 AM • eMachines T3508... • Answered on Jun 26, 2012
Boot file is compressed
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cablesAnothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
5/25/2012 1:21:40 AM • eMachines T3508... • Answered on May 25, 2012
How do I restore bios?
If all you have done is change the CMOS battery then the BIOS should be fine but it will have been reset to default settings which may have changed the Boot device and / or boot sequence.Go in to the BIOS setup when you power on the computer and check that you have your main hard disk drive set as the main boot device.
1/15/2012 3:56:24 PM • eMachines T3508... • Answered on Jan 15, 2012
Hi, can I use a
Your eMachines T3508 has one PCI-Express (PCI-E x16) slot available, so yes you can use this card with it (this video card for newer Pentium 4 motherboards with PCI-x slot).
1/5/2011 11:11:39 PM • eMachines T3508... • Answered on Jan 05, 2011
Hi would I be able
1/5/2011 11:10:59 PM • eMachines T3508... • Answered on Jan 05, 2011
The proper recovery screen comes
It seems that there is an virus on your computer try the below steps
Download and install: HiJackThis. http://www.majorgeeks.com/download3155.html
(Always create a Folder for HiJackThis anywhere but your Temp/Temporary Internet Folders or Desktop. A good place to make a folder would be in My Documents, as this is where it will save the backup files needed if there's a problem.)
Then doubleclick HijackThis.exe, and hit "Do A System Scan And Save Log". Make sure all Windows and Browsers are closed.
When the scan is finished, best to save your text file in the same folder as where you put HiJackthis.
IMPORTANT!!!
Create a New Topic and include a fresh HJT log in the HiJackThisLog Help Forum and Copy/Paste the info from your saved Hijackthis log file into your new topic.
A Moderator/ Security Team Analyst will give you instructions.
12/19/2010 5:06:08 PM • eMachines T3508... • Answered on Dec 19, 2010
2answers
Need to know which style of m b I have is it an
The difference between ATX and MicroATX is the size. An ATX board will usually have 6-7 slots to add cards like video, network or sound cards. An ATX board will also usually not have a video port on the board. A MicroATX board will usually have only 3-4 slots to add cards into it, at least one of which being dedicated to AGP or PCI Express Video cards.
To answer your question: That computer uses a MicroATX board. A Micro ATX board will most likely work in any PC Case whereas an ATX board requires an ATX size case (Mid or Full size Tower).
6/7/2010 5:45:48 AM • eMachines T3508... • Answered on Jun 07, 2010
Can I restore my eMachine T3508 to new without the
There is a good chance that you could restore the computer without the restore discs. It all depends on if there is a recovery partition built into the machine. Here is what you should do:
1. Restart your computer.
2. Tap F11 a few times before the windows loading screen.
3. Choose to restore your computer if step 2 worked.
After that your computer should be like new.
If you don't have a recovery partition try contacting microsoft and see if they can give you a copy of the operating system you are running. Just make sure you have your product key handy. It should be located somewhere on the case. Good luck.
6/3/2010 4:31:53 AM • eMachines T3508... • Answered on Jun 03, 2010
Trying to use system recovery disk that came with the computer
With the Recovery Disk in the DVD drive, just go and do a complete drive wipe and reinstall.
9/22/2009 2:32:04 AM • eMachines T3508... • Answered on Sep 22, 2009
2answers
I cant do a system recovery
the recovery has gone corrupt so please arrange the recovery cd.
7/9/2009 4:10:35 AM • eMachines T3508... • Answered on Jul 09, 2009
Emachine driver for windows vista upgrade
if you have the disc that come with your computer get the drivers from there.
11/18/2016 6:21:03 AM • eMachines T... • Answered on Nov 18, 2016
3answers
Screen says reboot and select proper bootdevice
Guessing, but it sounds like your hard drive has been damaged. You may need a new drive, or at least repairs. If you have a "rescue disk", give that a try.
9/5/2015 1:25:07 PM • eMachines T... • Answered on Sep 05, 2015
Emachine does not boot both fans are working
Here's a video on how I fixed my emachines boot problem. Almost anything can get in the way of your computer booting. Software, hard drive, RAM, motherboard, processor, etc. Below the video, I attached a link to a tip I made about computer crashes. Computer Crashes and Electrolytic Capacitors
7/1/2015 1:18:06 AM • eMachines T... • Answered on Jul 01, 2015
How to operat speaker
Please specify how exactly you're trying to make them work, what machine you're trying to make them work with, and what kind of connection your speakers are using. General info: Speakers usually get connected via 3,5 mm plug into the green round socket in the back or front of your computer. In Windows, if your speakers are properly connected and set up, right click on the sound pictogram in your taskbar and choose "Playback devices". Set your speakers to be the default playback device by left-clicking on the preferred device of your choise and clicking the button "Set default" below.
8/4/2014 12:53:28 AM • eMachines T... • Answered on Aug 04, 2014
Recovery disk for Emachine T5642
In general, you have to order recovery disks from the manufacturer of the machine. In your case eMachines Store eRecovery is where you can order it, or you can initiate a discussion with tech support. Also, many machines give you the option to burn your own recovery media when you first set it up. Most people skip this step. You should do this before you have problems. Search your machine for the word Recovery and see if you have an installer routine there. Here are instructions to create a recovery disk on a USB stick Create USB recovery drive Windows Help
7/30/2014 10:16:40 PM • eMachines T... • Answered on Jul 30, 2014
eMachines T3508 PC Desktop Logo
24 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T eMachines
  • T eMachines
Most Popular Question
able
  • Computers & Internet
