If this desktop can boot to BIOS properly, then you can download the BIOS file from Dell's website, make a bootable media (using other computer) and use this media to update your T3400 BIOS.
Test your PSU power supply unit or replace it if your power
supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htmTesting and replacing the PC power supplyhttp://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of
restarting or to shutdown or fail to detect ,boot up a computer hard drive
WARNING Before you
start troubleshooting remember that you are dealing with electricity that can
KILL. http://www.kitchentablecomputers.com/static.php
- rules
Only work inside the computer case when the power has been
switched off and disconnected. Never open the power source.
Some of the below steps
recommend removing physical parts within the computer.
While in the computer it is
highly recommend that you be aware of ESD and its potential hazards
Test all leads that attach to your hard drive power and data
cables IDE ,SATA
the leads from your
MOTHERBOARD TO YOUR HARD DRIVE
make sure they have a secure dust free connections and are not faulty or
just replace them they could be faulty
Make sure all leads that
are attached to your dvd \ cd floppy drives have secure connections and are not
faulty or just replace them they could be faulty.
Computers need power and
data to travel through every working device to continue its cycle and have an
end so any faulty leads will end up with a computer error.
Even something as small as
a faulty electrical or fan lead can cause you problems
Motherboard and a Hard Drive any leads between them will
fail before your motherboard or your hard drive if its a flat ribbon 40 pin
type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure
they are securely seated even the cd/dvd floppy drives need to have current go
through make sure these drives are working
also check the Cmos battery and computer RAM modules make
sure they are securely seated with no dust built up or in the sockets on some
motherboards cmos batteries are soldered in.
Check
you CPU central processing unit make sure its securely seated and has thermal
paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed
directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between
the CPU and HEAT SINK and preventing air gaps from forming between the CPU and
heat sink.
Another possible reason could be a memory dump you might be
running to many programs at the one time putting to much strain on the CPU
central processing unit.
If you can get your computer stable enough
scroll to bottom toolbar
bottom of screen right click select task manager
applications you will
see whats running if you see anything you dont need running select end now
also under processes see
what is ticking over again if you see something you do not need to be running
end now or you might uninstall that
program and some unnecessary programs
not having enough computer ram can cause memory dumps
If you are not sure if a module is right for your system use
the Crucial Memory
Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop
down list then select your product line from a drop down list then select the
model then click find it will take you directly to compatible ram also you will
have an option to scan your system
you should always for a guarantee on any ram modules when
purchasing them or buy working pairs if possible.
You might have a virus or malware.
Download at least one of these of course it will depend on
your operating system.
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be
registered
Win7/Vista/XP
64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62
anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
Capacitors look like small metallic canisters and they are
found in many different computer components including computer monitors,
computer motherboards, video cards, power supplies and a variety of other
consumer products.
A bad capacitor can cause a variety of computer problems,
but if you can identify the faulty capacitor you may be able to replace it and
save your computer.
CapacitorCapacitors, sometimes also called condensers, are used to
store energy in an electric field.
In the context of computing, capacitors are used to block
the direct current being circulated around the motherboard.
A typical capacitor should last up to 15 years, but some
computer manufacturers use substandard capacitors resulting in shorter
lifetimes.
Computer Problems
When a capacitor has gone bad on a computer you may
experience a large range of problems. The computer may have trouble booting up,
or it may shut down without notice after running for only a short period of
time.
The most common problems associated with faulty capacitors
are that they cause unexpected computer crashes and general reliability issues
ranging from read/write issues to distorted screen images.
Identifying a Bad Capacitor
To identify a bad capacitor you will need to open your
computer case and locate the capacitors on your motherboard.
A bad capacitor may exhibit swelling at the top or the base
of the capacitor or it may sit at an awkward angle with the motherboard, so
compare the various capacitors in your computer in terms of size and placement.
Additionally, a bad capacitor may have a funny smell or it
may have a brownish residue leaking from the top or the base.
Prevention
Manufacturers claim that capacitors may go bad because a
computer is not receiving enough power from a power supply, because of an
overclocked processor or because a computer is operating in an environment with
too much heat or humidity.
However, some capacitors prematurely fail due to faulty work
on the part of the manufacturer.
If you have a bad capacitor be sure to do research as to the
lifespan of other products made by your manufacturer.
Identifying bad capacitors
http://www.youtube.com/watch?v=ngA4k32jLGc
Capacitor replacement
http://www.youtube.com/watch?v=s0Pn2tEjY04
How to check a capacitor
http://www.youtube.com/watch?v=U4tnHA0phcc
Replacing a leaking capacitor
Could be a problem with the Hard Drive or the Hard drives
PCB
http://www.onepcbsolution.com/http://www.youtube.com/watch?v=du0Qd_3wFWM
Sounds like the memory is bad or not seated properly... take out all ram and then re insert it... 3 beeps can also mean bad video, so try the on board video card or reseat any video cards other then that If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
there is no master resest button , if your hardrive is not working it is most likely dead or has a loose wire.
hardrives arent designed to last for ever,what you can try to do is unplug the mains plug leave the pc for an hour or so , and then before pluuging it bavck in press the power switch this should clear all power from the motherboard and power supply.
you can also try reseting the cmos by removing the small battery on the motherboard. it is most likely you H/d is dead,following benwabnicks advice have you been able to see the H/d in bios. to enter bios press f10 or another key immediatley after powering up the pc, it usually tells you on screen press enter or f10 or another key to enter bios or setup.
remove all the external devices like printer scanner camera or hdd and restart the system or try safemode and run msconfig and disable startup items and try agian
To disable content advisor:--
1.Go to control panel.
2. Open internet options.
3. Go to content tab.
4. There on the content advisor tab, click disable.
5. Enter your content advisor password.
If it is just your home page it is a simple fix. If you can’t type an address as in www.yahoo.com in the address bar that is different. If you home page is the problem you can go into the tools-options menu and type the correct url in and save it. If you can’t go to any othe page it sounds like spyware or worse. Get good aitvirus and spyware removal programs and run them on your system. Of course that is hard if you can’t surf to any other site. You might have to take it in for service so they can place your hard drive in a clean system and scan it. If you can give more details I will try and give more specific help. Good Luck
Check and see if there not in a DPMI mode both on your monitors and the video card under display settings, if your rebooting to get them back on its a DPMI issue that just needs adjustment,
this 2007 year PC OLD, has many limits (CORE 2 is one)
is this windows 10? 64bit> I bet not its CORE 2 old)
I came with VISTA if MS loaded OS, or XP or RedHat Linux?
what boot menu are you talking about.? F12?
wild guess me, VISTA OS: (now zero support)
in windows, we have disk manager, do all devices show up now?
this is first, if not here, explorer can not work.
lets do the correct order:
1: bios sees my media. (good)
2: then in device manager, it sees them, if not drivers bad.
3: then Diskmanager sees the devices, and must have drive letter or next. if letters missing right click device and add one.
4: explorer (This PC) fails to find it. if above fails sure.
easy as 1,2,3,4 order, matters.
can't see CD does that mean a disk or the whole drive?
cant See HDD, is this HDD0 ,1,2, 3 or?
how many HDD do you have, and are there SSD drives there
and last what SATA ports are you using, some are limited.
here is your DELL.com support page, (12 years later still here)
https://www.dell.com/support/home/us/en/04/product-support/product/precision-t7400/drivers
what HDD fails,
does the PC boot at all? my wild guess NO.
what OS
what OS do you want to run, that be first thing to ask on any 2007 old PC, as Windows 10 will fail here. I Bet. for sure 64bit.
