20 Most Recent
eMachines T3616 Desktop PC Questions & Answers
Black screen
on booting press the f8 key then select the last known good configuration, check it
Need to clean every thing thats making computer
If your hard drive is too full, then your computer is going to perform slower. Delete old files which are not required.
Remove programs that you are no longer using. Delete temporary files.
Empty your recycle bin. Right click on Recycle Bin. Click Empty Recycle Bin>Yes.
Run an error check on your computer. The error check can remove errors that slow down your computer. If you are using Windows, you can do this by clicking Start>My Computer. Right click on your hard drive (typically c:) and then select Properties. Click the Tools tab>Check Now and then Start.
Defragment your computer. A fragmented computer runs less efficiently. By defragmenting your computer, your computer will operate in a more logical and faster way.
Clean up your registry. You can purchase software that will fix any registry errors on your computer.
Perform this computer maintenance on a weekly basis.
Sound card
Hi check if your sound isn't muted in the system. Go to properties of your sound card and see if the volume level is not down there and check also levels for waves and don't forgot check speakers it self. A there powered ? Are you using correct jack hole for signal out ?
If you need more help let me know
My computer is stuck in the configuring updates:
give it some time to install that update, if its still not working then might be possible that the update was not downloaded properly or it got corrupted while installation due to which its stucked on stage 3 of 3.
In these situations we can try to restart the computer into the safe mode and and then check which update is causing the computer to stuck on stage 3 of 3. If possible try to kill that update in safe mode too. To help you on that you need to provide me some more information.
Which operating system are you using?
My emachine screen is black after reinstalling
sounds like your hardrive is failing.wants to load and does some things but if all your getting is mouse cursor and loading screen hard drive is going up.secondly it could be a bad back door trojan.they do things like that to,
How to operat speaker
Please specify how exactly you're trying to make them work, what machine you're trying to make them work with, and what kind of connection your speakers are using.
General info:
Speakers usually get connected via 3,5 mm plug into the green round socket in the back or front of your computer. In Windows, if your speakers are properly connected and set up, right click on the sound pictogram in your taskbar and choose "Playback devices". Set your speakers to be the default playback device by left-clicking on the preferred device of your choise and clicking the button "Set default" below.
Recovery disk for Emachine T5642
In general, you have to order recovery disks from the manufacturer of the machine.
In your case
eMachines Store eRecovery is where you can order it, or you can initiate a discussion with tech support.
Also, many machines give you the option to burn your own recovery media when you first set it up. Most people skip this step. You should do this before you have problems. Search your machine for the word Recovery and see if you have an installer routine there.
Here are instructions to create a recovery disk on a USB stick
Create USB recovery drive Windows Help
T5026 bios download
Flashing the bios is a last-ditch move. What happened before that?
Did it work before you flashed it? If the unit is interrupted during clash, or if it is the wrong bios, your goose could be cooked.
Read this:
http://www.techpowerup.com/forums/threads/flashed-wrong-bios.180492/
There may be something you can use, especially if you have a floppy drive (a real one, not a usb-one).
You maybe can use flash drive in the usb port, but that's a long shot.
Good luck with that. I'd be looking at a new motherboard. They can be had pretty cheaply.
Problem getting recovery disk
I understand that you want to reinstall the Operating System on the computer.
Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer. To start the system recovery:- Restart the computer
- When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
- When prompted with a boot screen, hit the Enter key.
- After the system recovery program has loaded, follow the prompts to reinstall the operating system.
If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from
Recovery Media.
- Insert the disk labeled System CD into the computer's disk drive and restart the computer.
- When the eMachines logo appears on the screen, press the F12 key repeatedly.
- Select either CDROM or DVD as the boot device, this may vary depending on the system.
- When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first Recovery CD.- After the system recovery program has loaded follow the prompts to reinstall the operating system.
Refer the URL for more information and for the link to order the Recovery media if required.
How do i update my graphics card?
According to the port you have(pcle x16 or pcle x16 2.0), buy a new graphic card , open up the cpu cover and replace it with the old one.
