20 Most Recent HP TouchSmart IQ506t PC with Intel Core 2 Duo Processor T5850 ; 4GB DDR2-667MHz sy... PC Desktop Questions & Answers
2answers
How do I reset my hp touchsmart iq506 to factory settings
http://www.hard-reset.com/hp-touchsmart-hard-reset.html
9/21/2017 4:17:25 PM • HP TouchSmart... • Answered on Sep 21, 2017
Hi, Could someone tell me how to sort incoming mail by sender. It's so much easier to file and delete with that feature that appears to be gone.
You can hover over the senders name, then click on the magnifying glass that appears to the right, upon doing so it will search all messages by that sender.
11/22/2013 7:56:20 AM • HP TouchSmart... • Answered on Nov 22, 2013
I need instructions on how to install a motherboard
How to Dissassemble a HP touchsmart IQ770 http://www.youtube.com/watch?v=vpMrlAMSobQ This might not be your computer but it might give some insight on how to install the motherboard. Hope this helps.
1/10/2013 4:16:25 AM • HP TouchSmart... • Answered on Jan 10, 2013
My IQ506 cannot get out of the SLEEP MODE! I've
If it does not come out of sleep mode after pressing a few keboard keys or moving the mouse then the only other option is to switch the power off at the wall socket, then switch it back on. You may lose any unsaved work.
3/5/2011 12:08:54 PM • HP TouchSmart... • Answered on Mar 05, 2011
2answers
Blank screen on my HP IQ506 TouchSmart
Hi, you may need to do a system restore with your windows CD or try pressing the ESC button during boot up and select start in safe mode, from here you can restore your operating system to a time before the problem started. Hope this helps
7/29/2010 12:39:46 PM • HP TouchSmart... • Answered on Jul 29, 2010
I am trying to restore Windows wiht the recovery
The first question is why were you trying to restore Windows? What was the problem? The actual problem may have been a failing of the HDD to begin with. The message that there is no HDD is just that, either a interface connection has come loose from the drive or that the drive has finally failed. If you get another HDD, make sure that you run the included software with it to make sure that the new drive is "Initialized". Then you can load windows and start the load up process again.
1/7/2010 3:02:22 AM • HP TouchSmart... • Answered on Jan 07, 2010
Works for a bit, but goes blurry and freezes.
Sounds like a vid card problem
How do you get it to work when it freezes??
Ensure you have all the latest drivers from HP's site. Install them chipset first.
12/20/2009 9:23:26 PM • HP TouchSmart... • Answered on Dec 20, 2009
Computer freezes up
In case your system freezes at system startup, it usually implies that there are way too many programs loading at startup. Therefore, to fix these errors, you will have to stop unnecessary programs from loading during the startup process. To do this, first check the Start > All Programs > Startup folder. If you see any unwanted programs listed here, right-click and select Delete, to remove them. Next, open the System Configuration utility by running “msconfig” from Start > Run. On the Startup tab, clear the checkboxes of the programs that you do not want to load during system startup. Select Apply and click OK to implement the changes and restart your PC.
Computer freezes due to hardware, generally occur when different hardware devices
The problems may also occur if the device driver of a particular device is erroneous. You can resolve these errors with the help of the Device Manager (Control Panel > System > Hardware > Device Manager.) In Device Manager, locate the faulty device—depicted with a yellow triangle containing a yellow exclamation mark, right-click on it, and select properties. Here, on the Resources tab, you can manually modify the resource allocation of the conflicting device
Thanks,
12/9/2009 7:52:43 PM • HP TouchSmart... • Answered on Dec 09, 2009
I can't open the touchsmart page - even when I
type msconfigin start search and then click on startup tab and then click on enable all ,then apply.ok and restart and it wilm work
11/10/2009 1:55:22 PM • HP TouchSmart... • Answered on Nov 10, 2009
Touchsmart video is blank.
BAD SCREEN OR BAD VIDEO CARD VERY EXPENSIVE TO REPLACE IF YOU WHANT REALLY BAD TO REPLACE CONTACT HP
10/10/2009 4:33:41 AM • HP TouchSmart... • Answered on Oct 10, 2009
My HP Touchsmart T5850 has an issue with the screen blacking out
Try going into device manager and updating the drivers for the video card. if that dosent work check hp website for a firmware update.
3/11/2009 5:24:29 AM • HP TouchSmart... • Answered on Mar 11, 2009
2answers
Error code 80080005
Is your windows updates disabled? Is your anti virus up to date? Do you have a Malware program, updated? If you do not have MALWAREBYTES download and install :http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, may take hours, depends on HDD size. Delete ALL RESULTS. I don't know your OS? Vista? win7? 32? 64? Her is a standalone windows update for both 32/64:
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x86.exe or
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x64.exe
12/29/2018 3:29:51 PM • HP TouchSmart... • Answered on Dec 29, 2018
2answers
HP IQ772 power but no boot
all PC's fail. (Virus is #1 ) what OS (xp,vista, w7) ? is this PC in UK, England? HP shows, CIRCA 2007 build, (1st) and is near out of support) sure... you skipped the first steps. 1: battery out, get it out of the pc. 2: use only he a.c line pack , 3 it has PSU are all power pins reading correct voltage? must 4: if above ok, the BIOS works, on all systems, GET BIOS to work first. do you know your BIOS hot keys, its very important to learn this first if working on any PC made ever. 1981 to now. see this yet, the BOOKS http://support.hp.com/us-en/product/HP%20TouchSmart%20IQ700%20Desktop%20PC%20series/3351217/model/3561184/manuals?jumpid=reg_r1002_usen_s-001_title_r0001 best is not to pull any Cmos battery , just use a volt meter there, 3v is good, 2v bad. see? or scramble all BIOS setting including boot drive... arg. this box has no standard VGA 15pin jack on rear, making tests with external display hard use a flashlight pointed at screen see any data if yes the blacklight in the LCD is dead. (BIOS screens dead) does boot up, F11 bring up windoz recoverY. odd machine, wireless mouse and keyboard the latter begs the question gee how can we get to BIOS lacking a keyboard, driver in BIOS ROM. curious ,,, on line i see no body getting BIOS screens. fresh battery in keyboard, what happens here. If the hard drive errors happen before you can get to a recovery screen, try this:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter .
  4. Select a keyboard layout that matches your country/region and click Next .
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field (press Enter if you didn't put in a password) and then click OK . A System Recovery Options window opens.
  7. Click Command Prompt .
  8. At the prompt enter: c:
  9. At the c prompt, enter: chkdsk /b
  10. If a message opens saying you need to forcibly dismount the drive say yes.
  11. When it is done, try to do an F11 recovery again.
black screen has many causes. if its not just the back light dead, use a flash light first get BIOS to work, do you get F8 or F11 screens this is key to solving the true cause on all PCs. one can use a USB keyboard if yous dies. ask here , on the real forum. http://h30434.www3.hp.com/t5/Desktop-Video-Display-and-Touch/IQ772-Boot-Up-Problems/td-p/64527 i read your 2 users guides, no one word on BIOS that is BS. and due to now rear VGA port (has some mini bs jack) you cant see if the PC is dead or just the silly display or GPU chip dead., a preplexing box, i never buy those i get real DT or top HP laptops. all in one boxes are custom, and tricky to fix. for sure the nasty VGA trick missing, JACK
9/22/2017 1:08:34 PM • HP TouchSmart... • Answered on Sep 22, 2017
Welcome screen for windowr10 not accepting password
It seems that installation didn't go very well. I have done many upgrades and it picked user name and password. No problems. Try to get a disk with the version of windows 10 you downloaded so that you revert back to the previous version or do a repair. Since I am not in front of your computer and as a technician then i could find some other information.
10/12/2015 2:50:56 PM • HP TouchSmart... • Answered on Oct 12, 2015
When I turn on the pc it goes to a blank white screen how can I fix this
CHECK THE VGA-CABLE. TRY WITH A OTHER MONITOR.
4/19/2015 11:03:35 AM • HP TouchSmart... • Answered on Apr 19, 2015
2answers
Why does my computer fan suddenly run faster
As the cpu (central prossing unit also known as processor) heats up the fan will surge to cool it down. Nothing to worry about. If this helps you rate favorable.
2/24/2015 5:34:49 AM • HP TouchSmart... • Answered on Feb 24, 2015
How to make my crystal 660 printer compatible with HP touchscreen?
Drivers are created by the manufacturer. This is made by the Swedish manufacturer, Sagemcom. When I looked up the specs on the printer, I discovered that the manufacturer is Sagemcom. http://support.sagemcom.com/site/se/philips-fax-11/philips-crystal-660-337 Note that the top of the page tells you to go to a link for a critical update for the Crystal products. It will prompt you for numbers pertinent to your printer. When you look at the bottom of that page, you discover the printer is XP SP2 compatible. There is no mention of it being Windows 7 or Windows 8 compatible. Windows 7 driver.If you have Windows 7 Professional, Ultimate or Enterprise, you may be able to install your printer using Windows XP Mode. You will have no luck searching for support on a Philips page but may through Sagemcom as advised above.
2/20/2015 5:25:10 AM • HP TouchSmart... • Answered on Feb 20, 2015
HP TouchSmart IQ506t PC with Intel Core 2 Duo Processor T5850  ; 4GB DDR2-667MHz sy...  PC Desktop Logo
15 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
TouchSmart HP
  • TouchSmart HP
Most Popular Question
reset hp touchsmart iq506 factory
  • Computers & Internet
