20 Most Recent Dell Inspiron 530 PC Desktop Questions & Answers
3answers
My iolo registry repair damaged my cd rom registry
My first thought is to open Device Manager (Control Panel, System, Hardware tab, Device Manager button). Open DVD/CD-ROM drives by clicking on the + sign next to it, then highlight the drive and press DEL key. A message appears "Warning - you are about to uninstall this device" - click OK.
After it has been uninstalled, go to Action menu - Scan for Hardware Changes and the drive will be reinstalled.
Hopefully this will restore the function of your drive.
1/19/2018 5:09:11 PM • Dell Inspiron... • Answered on Jan 19, 2018
Youtube videos
Remove temporary files: install CCleaner, direct download from Piriform.com and let it run several times. First set this notch also under CCleaner Windows old prefetch data and then let it run. ce404d8a-d6a1-483e-961b-6416e57aad21.png Next goto Start - Control panel - under Programs: remove Programs and look for any unused programs: uninstall these. My Windows is dutch so this picture is of a dutch version of Win7. eeb7672f-a999-48c0-aec0-fbd6c4a8955b.png Then goto the folder where you have downloaded your youtube movies and remove very old ones you do not want to see anymore. Movies tend to be rather big in space. Now you should have some space again. If you want to know which files are biggest: install also from Piriform: Defraggler and open it, on the next tab File list you will see a list with the biggest files at the top: 0bbe3c61-ea0d-42ae-91b1-34aef8a5b21e.png If you have an SSD drive you do not need to run Defraggler to defrag your harddisk, Win 7 will take automatically care of the SSD, on a Sata drive however it is very wise to let Defraggler do its job and reorder the files so that all parts of one file are in line placed on the harddisk, which makes accessing it a lot quicker. So reading time of the data will be some faster ( less waiting time for you). You might also consider moving your documents and files to another disk. This might be an external harddisk with USB, or a new disk added in your computer, then you need a connector on the motherboard to be available. Have a look at these movies and info: https://www.youtube.com/watch?v=Jbb9xrR49d8 Or you will need something like: http://www.seagate.com/products/laptop-mobile-storage/laptop-external-drives/ http://windows.microsoft.com/en-us/windows/install-remove-hard-disk-drive#1TC=windows-7 http://windows.microsoft.com/en-us/windows/change-add-remove-drive-letter#1TC=windows-7 Relocating documents to another drive: https://www.youtube.com/watch?v=G5GK10DGLZk Good luck !!
8/30/2014 7:44:32 PM • Dell Inspiron... • Answered on Aug 30, 2014
0answers
2answers
Deleting the Upper and Lower filters in regedit
Try the steps below:
You can click the link below and when microsoft's site comes up scroll down and click Fix It or you can do it yourself with the instructions below the link based on your operating system. If you have windows 7 the Fix It will not work, you will have to do it yourself by the instructions under the link.
http://support.microsoft.com/kb/314060
Windows 7
To resolve this problem on a computer that is running Windows 7, use the Hardware and Devices troubleshooter. For more information about how to open this troubleshooter in Windows 7, visit the following Microsoft Web site:
http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooter
c:%5cdocume%7e1%5cowner%5clocals%7e1%5ctemp%5cmsohtml1%5c01%5cclip_image001.gifBack to the top Windows Vista
  1. Click Start
, and then click All Programs.
  1. Click Accessories, and then click Run.
  2. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  1. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  1. In the right pane, click UpperFilters. Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  2. On the Edit menu, click Delete.
  3. When you are prompted to confirm the deletion, click Yes.
  4. In the right pane, click LowerFilters. Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. Exit Registry Editor.
  8. Restart the computer.
Now go to the "Did this fix the problem?" section.
c:%5cdocume%7e1%5cowner%5clocals%7e1%5ctemp%5cmsohtml1%5c01%5cclip_image001.gifBack to the top Windows XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:
  1. In the right pane, click UpperFilters. Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
6/3/2012 11:29:31 AM • Dell Inspiron... • Answered on Jun 03, 2012
How do I enable my computer for bluetooth?
first of all make sure that bluetooth device is one from BIOS.
install the bluetooth software.
make sure the bluetooth switch is on
8/21/2011 3:42:49 PM • Dell Inspiron... • Answered on Aug 21, 2011
I have a Dell Inspiron
When you flash the wrong BIOS, the motherboard is broken for good unless you have the factory utilities, which (I'm assuming you don't work in a Dell factory) you don't. Sorry. Your best bet is to buy a new motherboard and switch all your parts onto that mobo.
6/8/2011 7:52:15 PM • Dell Inspiron... • Answered on Jun 08, 2011
2answers
Desktop blue screen problem: UNMOUNTABLE_BOOT
your pc was corrupt, reinstall your windows
1/24/2011 5:58:46 AM • Dell Inspiron... • Answered on Jan 24, 2011
2answers
Hi, I have a problem with the scrolling bar at the
Hello
This problem of your computer is not due to mouse, i believe your computer is responding slow due to some reasons:
1. Lot of application installed on it, do uninstall software you dont want. 2. Clean the temporary file from your computer 3. Check and Remove hard disk errors 4. Check and clean virus/spyware
You can get helps from this web site as well http://www.microsoft.com/atwork/maintenance/speed.aspx
Hope this helps, if so do rate the solution
1/6/2011 2:42:28 PM • Dell Inspiron... • Answered on Jan 06, 2011
2 dvd burners don't recognize that dvd is in drive
O[pen cpu cabinet then reconnect your both connection to dvd drive power cable and ide cable both.
(1)You need to delete upper and lower filter keys in registry.
For that Press windows key +R so you can see run then type in run "regedit" then press ok.
Then you can see registry editor.
Then locate following key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
Then delete upper and lower filter.
Then restart computer then check.
If still you can not use cd/dvdd then you need to change or repair cd/dvd lense in cd/dvd rom.
Then it will work again.
Let me know if you need further assistance.
Thanks for using FixYa.
4/16/2010 4:11:49 AM • Dell Inspiron... • Answered on Apr 16, 2010
Dell 530 won't boot up
Try booting up in safe mode COMMAND PROMPT ....
Type CHKDSK /F
CHKDSK cannot run because the volume is in use Type Y and push enter it will start on the next startup...Restart the computer... If that doesn't work take the hard drive out and connect it to another computer and run it on that...
4/9/2010 6:57:49 AM • Dell Inspiron... • Answered on Apr 09, 2010
2answers
How do I remove a trojen virus
Require to install an Antivirus application on your Computer (ex: McAfee, symantic, etc) and next update it from website for latest version.
Once it updated, Open antivirus console(Wizard) - Select On-Demand Scan option - select All Drives and files you required....
It will take few minutes.. (it lists virus detected - if it not critical file). In Action you can select apropriate action (Delete or protect it from infecting other files). Also you can select auto action for the same.
If you require more help let me know...
3/19/2010 9:02:54 PM • Dell Inspiron... • Answered on Mar 19, 2010
2answers
I am having a problem
Try this, install the IE add-on for Mozilla Firefox. Then click to an Internet Explorer only site and switch from the Firefox browser to embedded IE in Firefox using the IE tool. If the page renders correctly, it means that all the files and libraries in IE are good, which the IE tab tool uses, and that the problem is a component add-on or tool bar that has corrupted either you local profile or the all users profile.
WINDOWS XP ONLY:
Create a new user and log in using the new account. If the problem goes away, it is part of your IE user profile. If it does not, it is part of the All Users Profile that is corrupted. If the problem is your user profile, then set the file properties to view hidden and system files and delete the c:\documents and settings\[username]\Application\Microsoft\Internet Explorer
Otherwise, delete the corresponding folder from All Users.
WINDOWS 7 and VISTA:
Use the network and Internet tool to reset IE7 to it's default settings and then wipe cookies and temp files.
3/6/2010 8:22:01 PM • Dell Inspiron... • Answered on Mar 06, 2010
2answers
I have a Dell Inspiron 530. Over the past week, my
ljdigiovanni
From what I can HYCOM HY 05 is the onboard computer speaker that makes the beeping. On some systems it would produce the Windows sounds as well. So in your case it somes like the component has gone bad and/or something else on the motherboard is bad.
So I would recommend that you contact Dell support to see if you are still in warranty so they can get you a replacement motherboard.
Let me know if you have any more problems or questions.
Issken
3/2/2010 3:34:39 PM • Dell Inspiron... • Answered on Mar 02, 2010
This is for my Dell Inspiron 530 Foxcom
Hi
From what you are describing the power outage has caused the motherboard and/or the CPU to short out
Answering the question of where can you get anohter on, I belive you will need to book the PC into a PC repair shop to assess the damage and I am sure they will be happy to talk you throguh the options you will have
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank You again
2/12/2010 8:07:22 PM • Dell Inspiron... • Answered on Feb 12, 2010
2answers
When I have two monitors plugged in, machine
  1. If the system has integrated video with a DVI expansion card, you can use two monitors.
  2. If the system has a PCI-E dual head video card (2 video connections on the video expansion card) then you can use 2 monitors.
  3. If the system has a single head PCI-E video card (ATI HD2400) with a single DVI port, then that card disables the on-board VGA port.
So first you have to find out what the hardware configuration actually is for the Video Card. Then we can look at the monitors and how they are connected.
Post back with details on the video card and the monitors you are trying to connect if you need further information.
1/18/2010 7:15:15 AM • Dell Inspiron... • Answered on Jan 18, 2010
My computer will not display my homepage
Open internet explorer, manually type in the address of the homepage which you want goto Tools/Internet Options. Under the box which says homepage selct use current page.
11/18/2009 11:00:12 AM • Dell Inspiron... • Answered on Nov 18, 2009
Cannot download pdf docs on vista OS
you need get a program call adobe pdf reader and then you can download them and save them i hope this helps you out. Guy
11/9/2009 4:34:44 AM • Dell Inspiron... • Answered on Nov 09, 2009
I accidently blocked a pictures from my computer
You unblock it with a hammer...A REAL ONE hope this helps you it sure helped me with my ex wife :)
10/17/2009 3:47:34 PM • Dell Inspiron... • Answered on Oct 17, 2009
Green LED on Dell Inspiron Desktop 530 - all OK?
Yes, on most desk top the green light in the back tells you that you have power to the cpu. Even though the unit is off it is telling you that the current supply is still there. This is a good feature if you move your unit as soon as you plug it in you know if the outlet is on or not.
10/17/2009 2:07:14 PM • Dell Inspiron... • Answered on Oct 17, 2009
Noisey cooling fan on graphics card.
Pretty much you are looking at replacing the entire card. Fans can be found but it is difficult and it is not worth the time generally to find them. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127368
10/15/2009 10:28:48 PM • Dell Inspiron... • Answered on Oct 15, 2009
Dell Inspiron 530  PC Desktop Logo
Popular Tags
27 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
deleting upper lower filters in regedit
  • Computers & Internet
