20 Most Recent
Acer Veriton L410 Desktop - AMD Athlon 64 X2 4000+ 2.1GHz - 1GB DDR2 SDRAM - 1 x 160GB - DVD-Writer ... Questions & Answers
My Acer L410 continually restarts.
I have 2 suggestions. First, try different keyboards/mice. I've had similar problems in the past with the drivers for usb peripherals not working after updates or re-installs. usually the older and more basic a mouse/keyboard is, the more likely it is to work in this situation. if you have old mouse and keyboard jacks(the round, purple or green ones that look like s-video), use them. Second, if you are running windows 7, when you get to the boot options, don't select 'safe mode', instead look at the other options below. there should be one called 'boot without driver signature enforcement' this may allow the computer to boot normally and restore keyboard function, however, it is not a solution and if it works, it indicates that you most likely have a malware problem. after you get it to boot, immediately start a scan with a reputable anti virus program (I recomend malwarebytes http://shop.malwarebytes.org/lpa/342/4/7268/free_g.html?x-at=regGcbmd ) then use the kaspersky rootkit remover. (http://support.kaspersky.com/faq/?qid=208283363)
Warning your chassis has been opened
Hi need help asap.
I opened my acer desk top box to clean dust out and now has warning chassis open.
I cant access the bios or anything else. Does someone have a suggestion????
Panicking
How do i install an ssd to replace hard drive
The drives will usually come with a utility to copy your old drive to the SSD and make the SSD the bootable drive. You just need to have both drives connected at the same time. Check for download instructions in the packaging with the drive or check the manufacturers website.
Desktop wont start up
Need more info here please. What kind of computer is there any beep. Try to unplug your computer then while it's unplug hit the power button. Then plug Back in see if this helps
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
How can i reset my administration password if i
Use your windows disk and reset the password from there.
2. Boot into safe mode (using f8 at startup) and you will be logged into the built in admin account where you can change the other admin passwords.
3. Use the free Trinity Rescue Kit to recover the admin password.
