20 Most Recent
MSI M670 Notebook Questions & Answers
Msi laptop
Pull out the hard drive and see if it boots, then plug the hard drive in with the machine on. Follow any messages that appear.
10/15/2017 10:40:55 PM •
MSI M670...
Answered
on Oct 15, 2017
Powering on but no display
hi
plug in another monitor to your laptop
if the monitor works
your LCD screen needs to be replaced
if that monitors dark as well your LCD screen is ok
but you have to replace the inverter
cheers
5/28/2015 2:45:26 PM •
MSI M670...
Answered
on May 28, 2015
Which boot device should I select
You question is not clear: what do you mean about a "boot device" for your MSI M670 Notebook?
If your MSI M670 Notebook won't boot, you have a problem with some boot file, boot sector or even with your hard drive.
You should make a dianosis to your notebook with a bootable repair CD. A greatv tool might be Hiren's BootCD 15.2
Hiren BootCD 15 2
5/11/2015 1:45:07 PM •
MSI M670...
Answered
on May 11, 2015
How do i turn on
Hi
please try this it may work with your msi notebook
HOPEFULLY TO INSTALL WEBCAM
START
ALL PROGRAMS
ARCSOFT WEBCAM COMPANAIN
LAUNCH UTILITY ARCSOFT WEBCAM
INSTALLING WEBCAM AND SOFTWARE?
THEN YOU SHOULD SEE DRIVER SOFTWARE
INSTALLED CORRECTLY
NOW TRY AGAIN WITH THE FN+F6
8/13/2014 10:57:18 PM •
MSI M670...
Answered
on Aug 13, 2014
How to connect wifi in msi ms-145 notebook?
Based on the specs I looked up. The laptop does not come suppied with a wireless network interface.
These are the specs based on the limited part number given.
You will have to get and install the PCIe mini card / Wifi controller.
Wireless LAN Support a full-height PCIe mini card (MS-6894 and MS-6890 applied here)
You can also find many good USB WIFI adapters that will also work.
White pages referenced:
http://www.msiwhitebook.com/product_spec.asp?model=MS-1454-ID1
11/22/2013 7:31:44 PM •
MSI M670...
Answered
on Nov 22, 2013
Mouse not working
External Mouse or Touchpad? Try this, unplug, remove battery, plug in, reboot. Any change?
1/6/2013 10:09:55 AM •
MSI M670...
Answered
on Jan 06, 2013
How to put a wallpaper on a msi
Your laptop wallpaper creates an ambiance to your desktop. It opens many different avenues to represent your laptop's purpose. You can set the wallpaper as an artistic image that you like and would like to share, for example a photo during a vacation. Or if your laptop is used for business, you can use the desktop wallpaper as a tool for advertising your company. Your desktop wallpaper is a great feature to learn how to set so that you can update the look of your laptop with your life. Right-click on the desktop to open the pull down menu. Be sure not to click on any icons when doing this as it will open a pull down menu for that specific folder or program. Scroll to the bottom of the pull down menu and click "properties." A "properties" window will open. Click the tab at the top of the window that is titled "Desktop". There will be an image of the currently displayed wallpaper and a selection box below. Scroll through the list of images to find a new image and click on it or click "browse" to select your own image from your computer and then click "OK". Hope this helps.
1/5/2013 11:05:40 PM •
MSI M670...
Answered
on Jan 05, 2013
