20 Most Recent
HP Pavilion dv5-1150us NoteBook Questions & Answers
I have had this problem
old DV5-1150us.
vista , vista is good, but not supported, XP is 100x worse..
monitor , you mean the screen, and the Vista mouse is acting wrong. (correct?)
the only word above useful are vista and SCROLLING
not photos posted of the IMAGE on screen wrong.
try a real USB mouse yet, to see if a real mouse works.
that be first. if only SCROLLING FAILS.
this PC can be connected to a real VGA monitors.
see that 15pin jack on the back, if you use a real monitor as test
we can see if the screen internal has problems.
i cant see what you see, and this is like 1000 times more important
a picture is worth a 1000 words. see?
cell phone camera dead? cant send a photo here.
see below here (see icon blue "Photos" one of the most easy forum on earth to post a photo here.....
my guess is your screen is bad.
to prove that attach any disktop screen to VGA Jack.
if the laptop pad is bad, mouse pad use any USB mouse made
plug it in and see if a real mouse works, can be bought for $3 a real mouse on fleabay or borrow one.
Hello, I just bought a HP Windows 7 dv5 laptop a
leave the battery out, THIS TIME !and use AC only, batteries can short. dig?DV5 tells us nothing there are 9 classes of DV5made for many years.and with a name what is the namePavilion?the LT has a service tagnever ask for help lacking the full product name,as see here, a photo. a random guess,at #eg (circa 2008)HP Dv5-1017nrthat tells us what it really is.i dont need your nameor your serial number ever.just the model, see? photo belowsee link, and cure.http://jeepdied.com/look/puters/dead-screen.html
I have a HP Pavilion Entertainment PC. It worked
It could be a problem with the update. You could have used system restore to go back to before you installed the update. Re-imaging probably cancelled that. I would check for virus' before going any further. Download a program called malwarebytes (free version), install-update and scan. If nothing comes up try the system restore or uninstall the service pack. You can always reinstall it again later.
How do i reset a cmos/bios pasword on a compaq
The power on password is a little harder to break in laptops than desktops and this tip may or may not help. Each computer manufacturer is different in how they set thier systems up. Disassemble the laptop down to the chassis where the RTC battery can be seen in its socket. Make sure that all power is removed from this device and remove the RTC battery. Let the motherboard sit without the battery in it for up to one hour. replace the RTC battery and reassemble the laptop. Do not put the main system battery in just yet, power on only with the AC adapter. Power the laptop up and if it asks for a password, just hit enter, if it still asks you for a password, type in "clear". If it still wants a password, then the only other option is to "short" the two contacts in the battery socket for the RTC battery, using a small wire to jump the positive and negative points in the socket, make sure nothing else is touched or you will Nuke your motherboard. With the battery contacts "shorted" power the motherboard up with the AC adapter, wait approx 1-2 minutes allowing the motherboard to post. Shut the board down, and follow the previos procedures for reassembly and powerup.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
