20 Most Recent
HP Compaq Presario CQ50-211NR Notebook Questions & Answers
Compaq persario CQ50-211NR
ok
wHen you power up the copmputer press F8 key then enter in enable vga mode then go to dispaly property and change screen resolution to 1024*768 then apoply and ok.
6/27/2010 4:23:07 AM •
HP Compaq...
Answered
on Jun 27, 2010
When you boot the laptop blank screen comes
Your problem sounds a little bit different. I can't even get to the login screen. Pressing Ctrl+Alt+Delete does nothing. Task Manager will not appear. The installation of Vista worked fine for the first couple of months so I know that all of the hardware and drivers were at one time working beautifully.
When booting into safe mode I see crcdisk.sys (the last driver in the list) loads and then the screen tries to go to the GUI. This is where my computer seems to be executing something like:
int i = 5;
int hangForever;
While (true)
try
hangForever = i / 0;
catch
{ /* 2nd verse same as the first */ }
All of my hard drives have had their file systems check with chkntfs. All hard drives work with the install disk.
4/21/2010 12:22:35 PM •
HP Compaq...
Answered
on Apr 21, 2010
My cq50-211nr laptop was accidentally dropped and has a crack.
Ordering the part and replacing it yourself may be just a tad cheaper, but at a risk, may break new screen or cause problems with more parts, I would take it to HP, then again, an LCD screen replacement costs about the same as a new compuer. It's really up to you.
Good Luck ;)
4/6/2010 10:29:05 PM •
HP Compaq...
Answered
on Apr 06, 2010
Heats up and shuts dwn
Hello kiran_bhatta,
I also had a similar situation like this. I had a prehistoric laptop with an AMD Athlon as its processor.
AMD had always had this reputation of having their processors heat up real fast.
The reason why your notebook shuts down is because it's trying to protect its hardware from damage like burning itself up because the temperature inside is just way too hot.
My best suggesttion will be for you to get a notebook cooler. Find a cooler has its fan or fans directed at your processor.
It also helps if you can use your notebook near a ventilation equipment like an aircondition or an electric fan to soothe the intense heat your processor generates while you do your thing.
My case was it would shut down if I watch videos, do disk cleanup or anything that requires a lot of work from your processor.
Hope this helps.
Art Pena
Tech Support
11/23/2009 5:05:58 PM •
HP Compaq...
Answered
on Nov 23, 2009
I have lost my all drivers of my laptop were these
The HP/Compaq website will have them under the support link. Lookup your specific model # and select the operating system you are using. A list of all available drivers will then appear. Download and install those that you need and then reboot. Hope this helps.
8/20/2009 6:49:26 AM •
HP Compaq...
Answered
on Aug 20, 2009
LAPTOP IS NOT TURNING ON
Sir,
) Typically you can start your computer in safe mode by depressing the f8 key at the same time you boot. That will tell your computer to load only the essential drivers and OS components to boot the window screen. From safe mode, you can delete, clean up temp files, or roll back to a new setpoint date when your computer was working. You can try this and clean your system of any p&rn flicks and viruses that may have invaided your system!
2) It is rarely a motherboard failure unless you did some major drop-testing of your laptop computer. Even then the hard drive or memory getting dislodged would be more normal course of action. The manual is very clear on how to open your laptop, check and see if the memory got shocked out of the shocket and check the HD for the same issue. Try removing and reinserting the HD and Memory sticks back into their shockets; then try booting.
3) Msy be your battery might dead. In some systems if the batter is dead it will not take any more charges and will not let you boot. Buy a new battery and replace it.
4) Any drop-testing conducted on your lap-top when it is on would cause major damage to the HD spinning disc to crash into the pickup head. This is called a HD crash and damage the information on the disc. Replacing the disc with even an empty disc at $50 which prop you to load an OS means the HD is trashed. Re-install the HP backup OS and any other software onto the new HD and go on with your life.
Thanks
Good luck
8/10/2009 5:09:15 PM •
HP Compaq...
Answered
on Aug 10, 2009
Laptop sound works when using earphones, but
When you plug in headphones, very often they get accepted automatically and the sound port changes in the OS accordingly as well. But when you unplug them again, it happens quite often that the OS is not switching it over on its own (even still happens in win 7). Just go into the volume mixer panel/options and change the output back to the port of your speakers.
8/2/2009 8:18:53 PM •
HP Compaq...
Answered
on Aug 02, 2009
Driver required for Coneaxant HD-Audio Smart audio
This audio driver is part of your Vista operating system. This is why there is no driver to download. You have two options to recover this driver,
1.Use the Recovery Disks for your laptop. Install them into your DVD drive, and follow the instructions. Suggestion; Choose -> Repair
If you do not have the Recovery Disks, (You are supposed to make them as soon as you get the laptop, OR, you can order them from HP.com/Support>Contact HP)
then this is your second option,
2a.Click on Start>All Programs>Recovery Manager>Recovery Manager
Follow the instructions. Suggestion; Choose -> Repair
2b.Restart the computer>then press -> f11 <- as soon as the ->
"Press <F11> for recovery", message is displayed on the screen.
8/2/2009 7:46:45 AM •
HP Compaq...
Answered
on Aug 02, 2009
How do i get rid of a W32 Gaobot Worm Gen thats on
hi follow these instructions
Follow these steps to download and run the tool:
- Download the FxGaobot.exe file from: http://www.symantec.com/content/en/us/global/removal_tool/threat_writeups/FxGaobot.exe.
- Save the file to a convenient location, such as your Windows desktop.
- Optional: To check the authenticity of the digital signature, refer to the "Digital signature" section later in this writeup.
Note: If you are sure that you are downloading this tool from the Security Response Web site, you can skip this step. If you are not sure, or are a network administrator and need to authenticate the files before deployment, follow the steps in the "Digital signature" section before proceeding with step 4.
- Close all the running programs.
- If you are on a network or if you have a full-time connection to the Internet, disconnect the computer from the network and the Internet.
- If you are running Windows Me or XP, turn off System Restore. For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
How to disable or enable Windows Me System Restore
How to turn off or turn on Windows XP System Restore
- Locate the file that you just downloaded.
- Double-click the FxGaobot.exe file to start the removal tool.
- Click Start to begin the process, and then allow the tool to run.
NOTE: If you have any problems when you run the tool, or it does nor appear to remove the threat, restart the computer in Safe mode and run the tool again.
- Restart the computer.
- Run the removal tool again to ensure that the system is clean.
- If you are running Windows Me/XP, then reenable System Restore.
- If you are on a network or if you have a full-time connection to the Internet, reconnect the computer to the network or to the Internet connection.
- Run LiveUpdate to make sure that you are using the most current virus definitions.
7/24/2009 10:27:55 PM •
HP Compaq...
Answered
on Jul 24, 2009
My screeen gets all blurry and i have these white
Is this all the time or with windows? If it is all the time then it is a hardware issue, probably the video card dying or the lcd dying. If it is only periodically then it might be a lose cable or bad hardware configuration.
7/17/2009 6:53:44 AM •
HP Compaq...
Answered
on Jul 17, 2009
Can't find waere to put the sandisk adapter?
the place where you insert it should be somewhere around the left side of your laptop. It looks like a narrow, rectagular strip and make sure your adapter fits in the slot.
Hope this helps, and have a nice day! ^_^
7/11/2009 7:56:40 PM •
HP Compaq...
Answered
on Jul 11, 2009
