20 Most Recent
Toshiba Portege R200 Notebook Questions & Answers
NO PUEDO ENTRAR AL SETUP
Usted no esta solo! Un usuario dice "tuve que llamar al servicio al cliente de escritorio de ayuda, ya que tomo un tiempo para establecer no tan sencillo '
Se 'suspendio' pero puede conseguir obtener el apoyo de:
http://www.toshiba.co.uk/discontinued-products/portege-r200-110/
You are not alone! One user says ' had to call the customer service help desk because it took a while to set up not so straight forward'
It is 'discontinued' but you may get get support from:
How to break a password
What kind of password do you mean? Bios start up, Windows log on?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Hi there sir, it's me again
Try this.
As soon as u start the Laptop, start hitting F8 Key Cont. it will take u Safe Mode, click on safe mode, may be cud find another user account, Go to Start - Control Panel - User Account - Select ur User Account and Remove the Password.
& if incase u dont have any other User Account, then u will have to contact ur Manufacturer or u will have to Restore ur computer to Factory Settings.
Thank You,
Your Support Tech.
Fixya.com
Manish Shirsikar
How to install win xp in toshiba portage r200 laptop
This is resolved by installing Intel Storage Manager drivers through "F6" option on XP Setup. YOU MUST HAVE AN EXTERNAL FLOPPY DISK (A Drive)...as the Portege doesn't come with one...and XP does not support USB or CD ROM for this particular function.
Toshiba R200 aniversary edition UK -LCD replacment
Hi there.
Yes some screens are interchangeable between laptops, the best way to find out is take the screen out and take note of the serial number behind the screen and the ribbon cable connectors to see how many pins they have (some laptop screens differ) if the serial numbers correspond and the cable fits then you should be good to go.
Good luck and thanks for using FixYa!!
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
