20 Most Recent
Toshiba Satellite L355D-S7813 Notebook Questions & Answers
Toshiba satellite p55t-a5202 laptop hibernates
I have had the same problem with my toshiba p55t-a5202 from best buy took it in 2xs then was without a comp for weeks. The 3rd time I just took out 14 screws on bottom(do not loose them) carefully removed bottom cover (push in and up at sides to remove) then found battery. I followed the wires to the middle slightly larger white plug. Then took a very small screw diver and pushed down gently in the flat spot while pulling gently to disconnect the plug. The side lights went out. Then pluged it back in the same way I took it out. I put all screws back on the bottom cover. Pluged it back in and turned it on and whallaa! My lap top was working and I didn't have to be without it for weeks!! I like this comp but will NEVER buy another one with an internal battery. I guess til the next time it not responsive! Ugh! Goodluck!
11/11/2014 7:03:18 PM •
Toshiba...
Answered
on Nov 11, 2014
Toshiba satellite c855-s5315 reset help please
This sounds like you have corrupt files in storage.
If you have made a boot disk or flashed a usb flash drive with the operating system, you may be able to recover your disk integrity.
If not and you cannot complete the steps below, contact TOSHIBA
Hope this helps
1. Type in the words "recovery media creator" anywhere on this screen. As you start typing the Windows 8 Search box will open.
2. As you type the name of the app you will see an app list show up onthe left
3. Click on the "recovery media creator" app
. Select [Yes] to allow the Toshiba App to make changes to this computer
5. Insert a DVD in your disc drive and select [Create]
6. You will prompted to insert a disc after each one is filled until the completion message below appears
7. Select [OK]
This completes you backup media recovery set!
H
Hope this helps
HH
4/15/2014 6:13:26 AM •
Toshiba...
Answered
on Apr 15, 2014
Labtop won't turn on
Turn on, hold F8 button down until boot menu appears. Download Norton Boot Recovry to disc from another computer. Install in ur CD/DVD drive. Boot ur computer. Or install ur operating system disc in cCD rom drive. Reboot computer, hold F2 button down, modify BIOS boot sequence so CD Rom in 1st boot device. Boot computer, repair or reinstall operating system.
9/8/2012 9:05:44 AM •
Toshiba...
Answered
on Sep 08, 2012
Where is the reset button on a toshiba laptop
There isn't one. Notebooks never have reset buttons, newer desktop's neither.
If you want to reboot, (cold boot) jsut hold the on/off button for 5-6 seconds. If you release it too early it will hibernate. Press the button firmly for 5-6 seconds.
9/10/2009 8:16:38 AM •
Toshiba...
Answered
on Sep 10, 2009
Chiconey webcam usb2
Try this. I fixed my problem with my souncard drivers not working by installing the drivers for XP, and the software for Vista. See if that takes care of the issue.
8/29/2009 2:59:07 AM •
Toshiba...
Answered
on Aug 29, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
