20 Most Recent HP 530 Notebook Questions & Answers
Hp 530 Notebook Recovery Disk errors, cannot start
If you trying to recover your pc from a recpvery partition on the hard drive, somewhere the recovery partions has had the file you need to process your request is missing. If you are using the disk that came with your system, you will need to perform a fresh install with formating your hard drive.
5/4/2020 11:23:43 AM • HP 530 Notebook • Answered on May 04, 2020
2answers
163 date and time not set
have you tried to set the date in windows and it does the same thing? if yes the the battery might be dead. If the battery is fine then you might have e mother board issue! If it is the latter then to save money just change the date and time when you enter the computer - you could even write a batch file that will set your time for you - look up NET TIME SET on google.coim
4/5/2020 4:17:43 PM • HP 530 Notebook • Answered on Apr 05, 2020
1720 smart hard drive detects imminent failure failing attr 05
go to hp website and download the latest firmware for your notebook
7/18/2019 6:15:43 PM • HP 530 Notebook • Answered on Jul 18, 2019
HP 530 wont boot Windows 7 DVD
the 530 came with XP or vista,. never W7, the HP support only supports those 2 OS, period. F9 key boots to anything and DVD , the DVD-r is bad or the DVD drive is bad, why not boot to USB stick? if that works then the DVD is bad. (burned wrong or drive itself bad.see? Tell us what media you are using? (WHO's from Where?) tell us what you want to do: 1: run XP,Vista or W7, what? if running XP or VISTA before, the F10 ( changed to F11 later) F10 loads the OS fresh, off the working HDD, partition called the HP recovery partition, this is how to get the 530 back as day one. if you use a Microsoft media, it will be missing key HP drivers and will be missing all HP software. a fact. again, where did you get your media.? my guess, is you MADE it from DVD-R , right.? using what ISO, from Microsoft or from HP? using what method (I use Imgburn? free, and is best) ask how. this PC is carbon dated at 2008, (1 more year of support left, hint) be wise to download all the below so when HP deletes all this soon. you have it. or buy the HP media kit. and never need to ask for it again. hp sells it. buy it. now. while still sold. btw2, many DVD drives are bad, or need service or cleaning and fail to read disks properly,for sure huge OS loads ! and when DVD does work , it takes 1/2 day to load windows we use USB sticks today, that work all the time and run fast. burn stick instead of the disk. and win. we use RUFUS to burn the ISO to STICK. (ask, millions do) then, F9 boot to the USB stuck called Udisk. it boots fast and works. (at least installs fully) if using MS, w7.iso, there is no guarantee it will work with all drivers working on a 530. you tell us... the Microsoft w7 load will takes a license key , the bottom sticker on the 530 has COA sticker , for OEM XP or VISTA, (unstated by you) only OEM Disks installs work with that sticker, if you buy W7 , its called retail and can work if luckly , sans all HP software with it. here is the official page. this works, every time. but MS does not support it now, updates are dead. and more. at MS now. they ended it 3 years ago.. and Vista last month. (yes, 1 patch was released for the In the news ciberattack) https://support.hp.com/us-en/drivers/selfservice/hp-530-notebook-pc/3375953/model/3375995
5/16/2017 12:23:30 PM • HP 530 Notebook • Answered on May 16, 2017
Hp530 not switching on
You need to check battery. It is probable dead. This is why notebook goes on and off.
9/6/2014 9:03:46 PM • HP 530 Notebook • Answered on Sep 06, 2014
Why does my laptop say plugged in but not charging
How old is your batter. My be battery gone bad.
6/30/2014 7:03:43 PM • HP 530 Notebook • Answered on Jun 30, 2014
D:/ is not accessible. Disk structure is corrupted and unreadable.
You may have simply 'cooked' the DVD drive and the motherboard on it fried. Replacement drives start at 20 quid for a desktop and 30 quid for a laptop. It's held in with 1 screw if a laptop. Remove the drive, get the model number and replace it.
3/10/2014 8:02:09 PM • HP 530 Notebook • Answered on Mar 10, 2014
My wireless switch is not working how can enable wifi
If Windows Vista, 7, or 8....Go to Start->type in Network and Sharing Center -> on the left side of the window open Change Adapter Settings -> right-click on the wifi adapter and choose Enable.
2/13/2014 10:40:16 PM • HP 530 Notebook • Answered on Feb 13, 2014
Driver ubuntu wireless
1/6/2014 6:34:53 PM • HP 530 Notebook • Answered on Jan 06, 2014
Enable wifi
go in control panel then internet options
10/25/2013 12:37:36 PM • HP 530 Notebook • Answered on Oct 25, 2013
Factory reset
Press "F8" on start, and select "restore to factory settings"
7/24/2013 8:17:17 PM • HP 530 Notebook • Answered on Jul 24, 2013
Hp 530 usb port
ALL USB ports? In Windows Vista , run Windows updates to verify you are current. Run HP updates software. Take a look at this and run the Microsoft Fix-It: http://windows.microsoft.com/en-us/windows-vista/tips-for-solving-problems-with-usb-devices
4/17/2013 4:14:33 AM • HP 530 Notebook • Answered on Apr 17, 2013
HOW DO I OPEN MY HP 530 SCREEN AND REPLACE A NEW ONE?
First you have to open the monitor casingSecondly you Remove the keyboard and the rest of the device to be able to open the cover of the entire screen with caution cables WiFiThirdly Remove the screws on the sides of the screen with the caution of their small size and dimension decoder screen cable from the back carefully dismantling screen cables from the front in a small plate and went cautiously can successfully change the screenWith best wishes luck
3/24/2013 8:53:56 AM • HP 530 Notebook • Answered on Mar 24, 2013
I need a product keys fpr my laptop please
The Windows installation code is printed on the Windows label that is attached to the bottom of your laptop.
2/12/2013 6:41:04 AM • HP 530 Notebook • Answered on Feb 12, 2013
It wont charge morethan 60%
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
10/11/2012 1:02:08 AM • HP 530 Notebook • Answered on Oct 11, 2012
No dvd support
then it is either your cd rom is faulty or the disc is not bootable disc.
10/10/2012 11:52:31 AM • HP 530 Notebook • Answered on Oct 10, 2012
HP 530 Notebook Logo
121 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
163 date time not set
  • Computers & Internet
